To cover or not to cover?
Discussion in 'General Camping Discussion Forum' started by Thewifie, Feb 10, 2017.
  1. Thewifie
    Thewifie New Member
    Jan 31, 2016
    Hi, everyone!
    I hear different opinions on covering a popup or not. Ours is stored outside in southern CA, with no shade. Tons of sun (lots of rain this year) snow. The coldest it ever gets here is about 35-40 in the dead of winter.
    Thoughts?
    Thanks for your help!
  2. kitphantom
    12,340
    1,339
    Using a cover is somewhat controversial. Most brands of pups do not recommend using a tarp or other non-breathable cover for them. That type of covering can lead to mildew, heat damage, etc.
    Most manufacturers seem to be OK with a breathable cover. some people don't like the idea of any fabric covering a camper, thinking that the friction and abrasion caused by the cover causes at least as much damage as weather and UV.
    We're somewhere in the middle. We have used a breathable cover on both pups and on the TT. In our high desert environment, covering is mostly for UV protection, plus some from bird poo, tree sap, and blowing dirt. However, most of the time our campers are not covered. Once camping season begins, it is just too much of a pain to keep covering and uncovering the camper. That's true even more so now that we have the TT, since that requires a ladder and both of us to get the cover in place. This winter, we had the TT washed and waxed at the end of the season, then covered it. It was only covered about 6 weeks, since I added an extra trip to my solo schedule, 6 weeks ahead of the first trip originally planned.
    Here's a section with discussions:
    http://www.popupportal.com/index.php?board=57.0
  3. 91Starcraft
    91Starcraft Member
    141
    Apr 14, 2016
    I wondered this too. We get several feel of snow and we just didn't want the melt off to cause mildew under the cover or hold water in there. The PO didn't use a cover just made sure the PUP was slightly slanted back so water had a direction to go instead of pooling in the top.
    We do clear the snow off after each storm, which has been a lot this year!!
    We've gone back and forth about getting a cover.
  4. crackerJack
    crackerJack Well-Known Member
    1,179
    355
    Jan 6, 2014
    Scottsville, KY
    If the camper will be parked for at least a month then I cover it with a breathable cover. UV is really hard on it.
    I camped near someone with a Coleman like mine, and same age. There camper was basement stored and looked brand new!
  5. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    I use a breathable cover for uv protection, and also keeps it clean when not in use.
    I've seen what the sun can do around here, it's quite brutal.
    not that much trouble to cover it. can do it in about 5-min.
  6. 91Starcraft
    91Starcraft Member
    141
    Apr 14, 2016
    What about the snow?
  7. sierrapup
    373
    38
    Jun 19, 2016
    what snow..? [;)], but still the cover is water proof...and breathable..snow is the only thing keeping me from camping right now.. [:)C]
  8. 91Starcraft
    91Starcraft Member
    141
    Apr 14, 2016
    Me too and of course now all the water from the melting snow ugh!! Can't wait to get out there!!
  9. 94-D2
    94-D2 Happy Campin'
    2,281
    139
    May 21, 2010
    Sutter Creek CA
    I use an Adco tyvk cover. It transferres air (breathable) and protects from uv. It mostly protects from rain but some (little) will pass. Been using it about four years and it peromes great. Just don't use a laminated tarp. That will cause you problems.
  10. kitphantom
    12,340
    1,339
    Our biggest concern has been UV. On the pup, we had a breathable cover (no Tyvek) and the water would soak through - it dried very quickly, though, so that didn't concern us. The first (tiny) pup sat unused for several years, before we renovated it. We didn't bother to clean off the snow, but the top was sloped enough as it was parked that the water drained off.
    With the second pup, I would try to clean any accumulation of snow off, in part because the water draining off of the pup would refreeze on the concrete driveway.
    We now have a TT, so there's no cleaning the snow off the roof of that. As with the pups, the slope of our driveway allows the rain or melted snow to drain off. After one big storm last year, with a longer cold spell, I had to work at the ice that formed on the driveway from the melted snow.
    [The cover for the TT is an ADCO Aquashed, with a Tyvek roof, breathable sides. AFAIK, precipitation does not soak through on the roof, but it will soak the breathable sections - again not a a problem in our climate.]
  11. sleach
    697
    166
    May 17, 2014
    Boulder, Colorado
    An ADCO cover came with the [ALPU] when we bought it slightly used. It takes under ten minutes to install and tighten up. The [ALPU] has sharp roof corners, and I pad them with foam pipe insulation. Based on a discussion here on the forum, this year I put a pair of pool noodles on the roof, running lengthwise, to help with water runoff.
    I think the greatest benefit we realize from the cover is it keeps out the dust blowing from the farm fields.
    In a few days I will de-winterize for my pilgrimage to Phoenix, the re-winterize for another month and a half.
  12. tzmartin
    tzmartin Well-Known Member
    1,177
    544
    Sep 9, 2015
    i have a camco. waterproof on top, water resistant on sides. has flaps that ventilate. straps ho,d it down on sides. keeps the pup clean and saves the roof from UV. cheaper than building a shelter.
  13. West Coast Canuck
    1,659
    69
    Mar 3, 2005
    I have had good experience with Adco cover on my TT, it kept the exterior clean and spiders out of the exterior vents for the fridge and furnace. Unfortunately the first cover lasted 4 yrs before the wind finally tore it up for good. I bought a new Adco designer series one that almost twice the cost of the first one that is vented for wind. So far so good...
  14. kcsa75
    kcsa75 Well-Known Member
    4,112
    2,126
    Sep 9, 2013
    Kansas City
    We keep out Jayco in a storage shed, but I use the breathable cover to keep the dust and dirt off.
  15. Whiteycracker
    Whiteycracker Active Member
    159
    46
    May 22, 2016
    South Chicagoland
    We keep our pup unlevel for water and snow drain. We have a Carver Cover and Love it. Pricey...But better than those cheap ones. Will never go back to another cover.
  16. NegrilJerry
    NegrilJerry Newbies in GA, we LOVE this site!
    112
    Mar 23, 2015
    I use a relatively inexpensive Camco breathable cover, a great value. I do noticed a little bit of the stitching is coming loose on one corner but I can fix that with ease. Ours is a 12 foot box and the 10 foot to12 foot model fits it quite snuggly so I don't need to use the side tiedowns at all.
    I usually use pieces of foam pipe insulation to protect it from the sharp corners, although I may file those corners down when we uncover her in March for the camping season.
  17. sierrapup
    373
    38
    Jun 19, 2016
    the good part of that story is.........it's ALMOST MARCH... [;)]
  18. CO Hiker
    CO Hiker Active Member
    282
    68
    Dec 6, 2015
    Colorado
    I use an Elements breathable cover to protect the plastic pieces and paint from the CO sun. Have had it opened twice this winter just to let it air out and it still smells like the day we cleaned it up after our last trip.
  19. carriermnky
    carriermnky Member
    130
    Jan 9, 2017
    In case more is added to this thread I'm bumping.
