Tongue Receiver "pin"
Discussion in 'First Time & New Camper Owners' started by jezter6, May 16, 2016.
  1. jezter6
    jezter6 New Member
    56
    May 4, 2016
    When my trailer was delivered, the guy said I needed some sort of "pin" for my ball receiver lock-down thing (I don't know what to call it).
    He gave me a cotter pin looking thing and said it would work in a pinch, but that the pin I should get is more D-shaped that connected all the way around and back to itself so it wouldn't fall out. I didn't really understand since we didn't have any pictures or idea of what it was.
    Looking for it at Walmart and Online - everything I see has this really THICK bar, like 1/2" or something, which is way too big for what I think I'm supposed to have. The cotter pin thing looks no bigger than like 1/8" or so thick.
    Can anyone point me to what I need?
  2. Keith Hawkins
    Keith Hawkins Active Member
    1,336
    Mar 8, 2015
    I would just go into anyplace that sells trailer hitches, hardware stores, Walmart, harbor freight (probably the cheapest) and grab one off the shelve. Should only be $3-$7 depending on what you get.
    Looking for the part with the Arrow pointing at it.
  3. kitphantom
    11,728
    835
    We have found them at the local hardware stores (Lowe's and True value), in the drawers of miscellaneous stuff. We actually have a locking coupler pin, as a deterrent for the opportunistic thief or vandal. It acts as a double-check for us too.
    http://www.amazon.com/CURT-25080-Coupler-Safety-Pin/dp/B001GN3H5A/ref=sr_1_1?s=automotive&ie=UTF8&qid=1463409688&sr=1-1&keywords=coupler+pin
    http://www.amazon.com/Master-Lock-2847DAT-Stainless-Adjustable/dp/B001B0QBZ6/ref=sr_1_5?s=automotive&ie=UTF8&qid=1463409659&sr=1-5&keywords=master+lock+coupler+lock
  4. jezter6
    jezter6 New Member
    56
    May 4, 2016
    Thanks!!
    When I looked at all those things the bar looked so much thicker than the cheap pin that was provided, but I didn't actually look at the PUP to see what size the hole might be.
    Every time I saw those, I thought they were to secure the ball into the hitch on the TV because they were so much beefier than what I had in hand. But the picture on that first link from kitphantom showed a picture of it in the right spot, so something like that must be right.
    Off to look further on the PUP to verify the hole.
  5. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,188
    630
    Jun 11, 2014
    Houghton, MI
  6. Keith Hawkins
    1,336
    Mar 8, 2015
    I lost one once - it will be the only one as well. When I got home and purchased a new Pin I immediately connect some aircraft cable to it and affixed it to the tongue. No more forgotten or lost pins for me.
  7. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    The part the ball goes into is called the 'coupler'.
    I have always used a padlock in the coupler latch. I have a set of three matching (one key) padlocks, one in the coupler and two on the roof latches.
  8. rabird
    6,695
    299
    TX
  9. Milktrk
    Milktrk New Member
    331
    Apr 17, 2014
    I use a coupler pin lock that I picked up at Walmart. That way I know the trailer is secured to the truck and the kids won't play with it when I'm not looking and lose the trailer off the ball driving down the highway.
  10. edh
    edh Active Member
    1,073
    Jun 2, 2008
    I can't believe they gave you a 1/8" cotter pin! You are lucky your camper made it home. I support what others said, get the beefiest that will fit the hole in your coupler and pick a design that cannot work its way out or be left behind on the ground. This is definitely not an item to save money on!
  11. Rob-N-Kat
    Rob-N-Kat Member
    136
    Aug 15, 2012
  12. 1380ken
    1380ken Well-Known Member
    2,045
    479
    Nov 7, 2013
    Mass
    When I first got my camper, I thought the pin was only to lock the camper from being stolen. I took three trips with no pin. I have a pin now.
  13. Rob-N-Kat
    Rob-N-Kat Member
    136
    Aug 15, 2012
    Yikes!
  14. jezter6
    jezter6 New Member
    56
    May 4, 2016
    I've got a separate lock for the coupler where the ball goes in. I just need something to keep that latch locked in while driving.
    Thanks all for the help. It's too rainy to go out and investigate the hole size today, but I will get something beefy that holds itself closed and hopefully can find a place to keep it mounted so I never lose it. Might not hurt to keep a spare in the toolkit though.
  15. Ductape
    Ductape Well-Known Member
    1,105
    98
    Jun 12, 2013
    All good advice so far. I prefer one that locks, as well as a locking hitch pin in my hitch receiver. A couple years ago I discovered these by "Bolt"..... which key to my ignition key for my Ford truck.
    Hitch pin....
    http://www.amazon.com/BOLT-7025285-Trailer-Coupler-Lock/dp/B00KQPMYF8?ie=UTF8&keywords=bolt%20coupler%20lock&qid=1463506272&ref_=sr_1_1&sr=8-1
    The hole in my trailer coupler is big enough to take their padlock, so this is what I use on my camper
    http://www.amazon.com/BOLT-7018519-Padlock/dp/B005FNKFYS/ref=sr_1_2?ie=UTF8&qid=1463506586&sr=8-2&keywords=bolt+ford+lock
    This is the locking hitch pin I use. I have a couple.
    http://www.amazon.com/BOLT-7018447-Receiver-Lock/dp/B005FNKFZ2/ref=sr_1_1?ie=UTF8&qid=1463506586&sr=8-1&keywords=bolt+ford+lock
    Now I don't need to worry about having a second set of keys with me.
  16. Natureangel
    975
    177
    Feb 28, 2016
    Illinois
    A trip to Ace and picked up the thinnest padlock did it for me.
  17. jnc
    3,921
    1,168
    Oct 1, 2014
    South Central New Hampshire
    I have always use a plain old padlock.
