Tool battery packs
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by l33tDad, Jul 31, 2019.
  1. l33tDad
    l33tDad New Member
    Jul 14, 2019
    Southern Tier / Western Finger Lakes NY
    Okay, I'm still in the planning phase for a complete tear down and rebuild of a gifted PUP ('85 Palomino Pony) and am thinking about electric. I'm an avid DIYer in construction and have a bunch of Dewalt 20v portable tools and 5AH battery packs. Our camper isn't going to have anything that needs 120v and I don't think that I'm even going to install that option and as such, everything inside will run on 12v (LED lighting, maybe a 12v pump for the little sink and a ceiling vent fan). My thought is, if it's possible, to use my tool batteries as a power source, but I can't find anything online that would be of any help. Any thoughts?
  2. eoleson1
    eoleson1 Well-Known Member
    2,247
    681
    Jul 5, 2011
    Macomb County Michigan
    I would be afraid that the excess voltage would damage some of the devices; the pump in particular.
  3. l33tDad
    l33tDad New Member
    Jul 14, 2019
    Right ... I guess my question is that if anyone knows of an adapter or something to get 12v out of the pack. I know that Dewalt has an adapter for USB (5v) so I can charge/power a USB device from a 20v battery pack, but I can't find anything for 12v. I understand how to make a simple voltage divider, but am looking for more of a "turn key" solution I can buy.
  4. NMroamer
    NMroamer Well-Known Member
    549
    290
    Apr 21, 2016
    Albuquerque NM
    Voltage converters are really not very efficient.
    You will lose a lot of power in the form of heat generated by the conversion.
  5. SteveP
    SteveP Well-Known Member
    1,529
    421
    Since you're in the planning stage look at 12/24 volt options.
  6. SteveP
    1,529
    421
    I realize you're trying to use what you have but:
    20v x 5ah = 100 watt hours
    12v x 35ah = 420 watt hours
    Assuming 90% conversion efficiency, which is very good, it will take 420wh/(100wh*.90) = 4.66 fully discharged 20 volt batteries to equal the output of a single g24 deep cycle battery at less than 50% discharge.
    Compare the cost of conversion vs the cost of a single g24 battery, at about $100 + the cost of a plastic battery box, about $10.
  7. roybraddy
    roybraddy Well-Known Member
    2,218
    789
    Mar 23, 2016
    King George, Virginia
    Don't know if your trailer has requirement for electric brakes... If so it is really hard to beat having a regular 12V automotive type battery for that requirement...
    My neighbor here just picked up one of those JOB SITE FM radio's that runs from a tool battery pack... Kinda neat haha...
    I took my weed wacker 20V battery over to his place to see if worked his radio and it didn't... Would not fit the slide... It seems there are a bunch of different styles of 20V Battery packs haha...
    Roy Ken
  8. l33tDad
    l33tDad New Member
    Jul 14, 2019
    No electric brakes, it has dry weight of 920 lbs.
    I agree with everyone that a deep cycle battery would be more efficient and I'm all a go on it as the power converter that's actually in the PUP works fine, but I'm not looking to power any more than 3 or so LED lights and maybe a 12v pump for the sink and/or a little roof vent fan. Nothing more. I have 6 of the 5AH packs, 3 of the 3AH packs and 3 of the 1.5AH packs. As stated, I'm just trying to use what I have is all. (I also have one of those job site Dewalt radio's and it is awesome lol)
    Maybe I'm overthinking the whole thing and for the few times that I would need battery, just get a 12v deep cell and hook it into the converter. The thing I don't like is that according to the manual I found for it, it doesn't charge the battery :\
  9. xvz12
    xvz12 Well-Known Member
    828
    465
    Apr 6, 2017
    New Plymouth, ID
    I bought an adapter from FleaPay that my works with my DeWalt battery packs, dc-dc regulator that reduces the voltage to 12 volts, actually you can set it anywhere from 10-20v. They came in various amp ratings, maybe something like this would work for you?
  10. tombiasi
    5,367
    1,001
    It’s just the wrong battery for this application. There is a time and place for MacGyver, this isn’t it.
  11. NavarWynn
    NavarWynn Member
    78
    37
    Jul 20, 2019
    SAV, GA
    Any appropriate Dc - DC step down buck converter is going to work, but the smaller ones have an output limit of a few amps - though these tend to be more efficient for low draw devices. If you were to build a rack to hold like 5-6 of your batteries, and plumb them all into a parallel 'pool' to feed several smaller converters (say one for each circuit - matching the convertor power output to the device draw), and switching power from the battery pool to each converter on demand, that'd likely be the most efficient way to do it. However, in the end, it's likely far less cost efficient than simply buying a proper deep cycle and feeding the draws directly. While possible, it seems like a lot of work, effort, and cost to do something you could do cheaper, easier, and faster - even given that you already have several $$$ worth of batts.
    If your primary concern is that the converter doesn't charge the 12V battery when hooked up to shore power, then just get a smart charger with a reasonable peak output, and plug it into the 120VAC output. Even the cost of that plus the deep cycle battery would likely be cheaper....
  12. lostboy
    lostboy Active Member
    190
    60
    Nov 13, 2016
    Lakeville, MN
    Did you ever try this and get it to work or did you just opt to buy a 12v battery?
  13. Rusty2192
    Rusty2192 Well-Known Member
    903
    351
    Jul 30, 2014
    Kentucky
    I have a few Craftsman 12V lithium ion batteries for the Nextec tools and had picked up a power source adapter for them on clearance years ago. It has a simple cigarette lighter plus a couple USB ports. I rarely camp without hookups so this setup works great for a couple nights with my single led light. I can get a couple nights worth of light out of a single battery and it will automatically shut itself off when discharged enough. On a longer trip to the Smokies I took my inverter plus the quick charger figuring I could recharge the battery in the car on one of our drives around the NP, but never even needed it.
    I just wired up a male cigarette lighter plug I had laying around right at the converter then plugged it in.
    The only bad part about my setup is that the power adapter shuts itself off after a minute if there is no draw. So I either had to turn it on each time I turned on the lights or just leave the light on, which did work fine for the couple hours of dark before bed in the summer.
  14. BillyMc
    BillyMc Well-Known Member
    1,216
    573
    Mar 25, 2018
    Get a smart charger and don't look back.:D
