Tool box essentials
Discussion in 'General Camping Discussion Forum' started by brainradio, Mar 13, 2010.
  1. jim1999
    jim1999 New Member
    1,645
    Jul 8, 2008
    East Central Illinois
    Instead of flares I would suggest getting a set of 3 warning triangles. Flares can be very dangerous. I once had the "pleasure" of watching a flare get clipped by a passing car and flipped up through the open window of a police car. Didn't take long before flames were shooting out of the car.
    But you are on the right track with mentioning some kind of warning device.
    For me:
    Warning Triangles
    Duct tape
    Multi bit screw driver and any extra specialty screw drivers that might be needed.
    2 quality adjustable wrenches.
    Spare fuses and bulbs.
    jack and lug wrench
    can of silicone lubricant.
    super glue.
    screen repair kit
    (when I had the pup) canvas repair kit and seam sealer.
    assortment of sewing needles and a spool of black thread.
    Utility knife
    scissors.
  2. scorp28
    scorp28 Member
    179
    Aug 9, 2009
    Elmwood, IL
    I would suggest a small magnetic parts tray for holding lug nuts or screws or whatever and a pair of gloves of some type, even if they are disposable, so that if you have to change a tire on the side of the road and your hands get dirty or greasy you wont transfer said dirt or grease to the inside of your TV.
  3. CarNutCass
    CarNutCass Put a little gravel in your travel
    805
    Mar 20, 2009
    St. Charles
    My tool contains the following:
    - Breaker bar
    - Sockets for lug nuts
    - Various screw drivers
    - Claw hammer
    - Hatchet
    - Electrical tape
    - Solderless crimp connectors (for electrical repairs)
    - Crimp tool
    - Digital multimeter (have used this more than once)
    - Allen wrenches
    - Cable ties
    - Flashlight
    - Spare fuses and bulbs
    I can't stress the importance of the multimeter enough. You can buy a decent one ar Wally Wold or Harbor Freight for $20ish.
    I probably ought to consider adding warning triangles...I like flares but would be afraind one of the kids might decide to try one out.
  4. UKDiamond001
    UKDiamond001 Active Member
    120
    105
    Aug 5, 2006
    Suffolk UK
    As well as the tools mentioned here, I would say carry a spare awning pole the same length as the distance between the roof and the top of the camper box, saved my holiday when a lifter cable failed. Just lift the top and wedge it in place.
  5. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,424
    902
    Jun 11, 2014
    Houghton, MI
    We hate to carry any tool that requires a battery. Point is, when or if you need it, then the battery is gone. We don't carry a meter with us anyway. Why do we need a multi-meter while camping??
  6. wmgeorge
    wmgeorge Member
    94
    25
    Sep 6, 2019
    Charge the batteries before a trip and I always have a meter with me, always.
  7. FARfetched
    FARfetched Well-Known Member
    686
    357
    Nov 22, 2018
    Sector 706, Planet Georgia
    Decent portable tools have interchangeable batteries these days. Keep a spare (charged) and maybe even bring the charger along if you have room.
    I found(!) a DeWalt 20V drill/driver in my garage, and bought a charger & spare battery. When the driver went missing, I sighed and bought a Ryobi 18V drill because I already have their circular saw (and batteries, and a charger). Then the DeWalt reappeared—which is good, because sometimes I need both.
    Something I didn't realize was essential until I saw it: my son in law has one of those compact booster boxes that uses a lithium-ion battery. Tons easier than maneuvering another vehicle into position for jumper cables! It also has an air compressor, light, and USB ports for charging the usual suspects. Besides the obvious things, it wouldn't take much to connect it to the camper wiring for emergency power. I thought the wife had bought it, and was bummed when he and DD moved out and took it with.
    Special case, maybe, but I keep a grommet kit and sewing kit in the PUP as well, for the thousand natural shocks that canvas is heir to.
  8. Anthony Hitchings
    840
    373
    Mar 2, 2019
    you might consider socket-wrench and hammer (yes!) to removing-replacing your leaf spring bolts (splined into the support bracket) to the frame and to the axle - as I found out on my last big trip. Or just buy them when you go to town to get the leaf springs.
  9. Anthony Hitchings
    840
    373
    Mar 2, 2019
    I second the use of collapsible red triangles.
    akriot likes this.
  10. Wrenchgear
    3,427
    684
    Aug 5, 2010
    5 Star Eagle Camper
    Wow, this is an old thread brought back to life.
    So, a few more things that I take that haven't been mentioned (I think),.....
    - tube of 5 minute epoxy
    - non contact electrical tester to check for power at 30 or 50 amp socket at the power post, or for hot skin on trailer
    - 15 amp plug in tester so you can check if the power post is wired properly. I do this every time before I plug in to the 15
    - I put together a kit for winter driving that I take along, it has a few tow straps, and hooks etc, to help out if you get stuck
    - booster pack for your TV battery
    - 1 set of wheel bearings for the trailer (pre-greased), and a grease seal
    - 12v test light
    - zip lock bag of variety of nails, screws, nuts/bolts/washers, cotter pins, hose clamps
    - tire plug kit and a small 12v air compressor
    - couple of extra wheel nuts for both trailer and TV in case something stupid happens
    - a liter of oil for the TV and a funnel
    akriot likes this.
