Top of bunk ends collecting moisture on the inside?
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by lovetocamp2010, Aug 2, 2012.
  1. lovetocamp2010
    lovetocamp2010 New Member
    64
    Mar 25, 2011
    Anyone else have this problem? I am a brand new pop up owner...5th time out since we bought it (1999 Camplite by Damon) and of our trip we are on now...we had a lot of rain one night and since we have had moisture drops building up on the roofs of the bunk ends and then when we flip over or move in our bunks during the night it feels like it is raining on you - do we need to waterproof our canvas or something? Any help would be welcomed! Thanks!
  2. kitphantom
    11,752
    851
    Do you have any openings for air circulation? Condensation inside is common in rainy or humid weather when there is not enough circulation. Bunk ends tend to be worse, since they are shorter ("floor" to "ceiling") and people are often in them breathing out humidified air, etc.
  3. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
    Covering the bunk end canvas will really help, too. The pic below shows one of those plastic tarps over the bunk end and just the tarp by itself helps. But under this tarp is a layer of Reflectix insulation which helps enormously. Now you can buy an already made up cover called a "Gizzmo" which are easily installed. The outside cooler air temperature vs the inside warmer temperature, and depending on the amount of moisture in the air, will cause the condensation to form. Plus add some people breathing inside (generating some more warm moisture to the inside air), and you almost have a rain forest in the the bunk ends! Like already posted, the first order of business is to vent ... unzip some corners, open the roof vent a little (if it's not raining!) and there are the panels on the door that can be opened.
  4. cwolfman13
    cwolfman13 Active Member
    3,218
    Feb 9, 2011
    This sounds like a classic case of condensation buildup due to improper ventilation of the p'up. Crack a couple of windows to get some ventilation and you should be all good.
  5. Unstable_Tripod
    14,279
    30
    May 20, 2008
    Seattle, Washington
    Yup. As the others said, open at least two windows a couple of inches, across from one another, for proper ventilation. Humans exhale huge amounts of water vapor over night. Also, getting Gizmos for the bunk end roofs ( to help keep cool/cold air out of contact with the canvas) is a great help. Gizmos help keep the PUP cooler when it's hot, too. And, they keep the canvas clean by preventing sap and bird dropping from getting on it.
  6. The Manchacan
    The Manchacan New Member
    114
    Feb 25, 2012
    Anyone mention condensation yet?
  7. kitphantom
    11,752
    851
    As others have mentioned, PUGs help a lot, by creating an air space above the bunk end roof. If you go in cold weather (<35-40*), the bunk end liners from PUGs help too, for warmth - when we did Grand Canyon in Nov. and the temps were in the teens to twenties at night, I found frost between the liner and tenting. However, I did not have a problem with condensation in the living or bunk areas, due to heater and air flow - in spite of hanging wet clothing inside (I walked for miles in the snow/fog).
  8. daveo1289
    daveo1289 Active Member
    974
    81
    Apr 24, 2012
    Rochester NY
    You may want to also turn a small fan on to keep the air moving in the PUP.
  9. surgipat
    surgipat New Member
    94
    Oct 1, 2011
    I also learned (the hard way) not to touch the canvas from the inside if it's raining outside. It wicks.
  10. daveo1289
    974
    81
    Apr 24, 2012
    Rochester NY
    Oh, so true!! Found out the hard way.
