Torsion Axle Lift DIY (Photo Intense)
Discussion in 'Tires / Brakes / Bearings / Axles' started by thelmuth, Feb 11, 2016.
  1. thelmuth
    thelmuth Member
    114
    19
    Nov 6, 2015
    Brooksville, FL
    As long as it fits, why not?
    BelchFire and vaderhater22 like this.
  2. vaderhater22
    vaderhater22 New Member
    17
    Mar 4, 2017
    Whiteland, IN
    I finally got around to doing this myself. It was really pretty simple. I think the hardest part was explaining the process to my father in law that helped me out and loaned me some tools. I haven't pulled it anywhere yet except moving it around the yard to work on it due to needing some work on my TV that I found out while working on this. But it looks good sitting there. It is much more level and I think I'm going to look into bigger wheels and/or tires to increase the clearance just a bit more. I took a few pics but they won't upload here. Says the files are too big.
  3. thelmuth
    thelmuth Member
    114
    19
    Nov 6, 2015
    Brooksville, FL
    Good deal. Told you it wasn't that difficult.
    vaderhater22 likes this.
  4. tenttrailer
    3,351
    415
    Jul 18, 2013
    Thornville, OH
    We did a 2.5 inch lift using hitch receiver tube.
  5. Silverbat
    Silverbat New Member
    Sep 2, 2019
    Hoping to revive this post and get some input. I have a 2011 Starcraft Centennial 3612 that sits really low. It scrapes the driveway when backing and can’t fit a grey water tank under it as the bottom of the outlet for the sink is only 8.5” from the ground. The 2 5/8” lift offered by dexter won’t give me the 12” height I need. I’m considering using a 4”X3” .25 thickness tube. Any thoughts on this would be helpful.
