Tow high or low
Discussion in 'Tow Vehicles, Hitch & Towing' started by kreich, Apr 25, 2012.
  1. kreich
    kreich Member
    718
    May 5, 2007
    Hale Center TX
    I just bought a 2012 Nissan Titan CC 4x4 and the receiver hitch is up there in the air stock. The A-Liner has a high hitch also but seem to not find the right receiver that will tow level. Would you tow with the tongue pointing up or pointing down. Would you put the ball lower than level or higher than level. We are talking about an 1 1/2" SWAG either way.
  2. jenoble99
    jenoble99 New Member
    379
    Jul 3, 2008
    Indiana
    If you can't get it level then it's better to be a little low than high. If high then wind can catch the under side of the camper and cause sway.
  3. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    +1
  4. Starcraft Away
    Starcraft Away New Member
    853
    Feb 10, 2012
    Defintely better to pointed slightly downward if you cant get it level.
    Cheers
    A
  5. johnsagraves
    johnsagraves New Member
    405
    Feb 1, 2010
    Dont think your going to have much trouble with sway on your tow vehicle. We pulled a Aliner last year using an old Grand Marquis and was all over the road. Bought the Isuzu Rodeo and it tows a straight as an arrow. We are getting ready for 7000 miles this summer. We found a slight bit down was better than up, but with your tow vehicle, you will have no problem. Stiff suspension is the key. John
  6. kreich
    kreich Member
    718
    May 5, 2007
    Hale Center TX
    Thanks will see what we can make happen.
  7. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    I have an adjustable draw bar with set holes every 1" . never had an issue finding a towing level within 3/4" up or down as close to level as possible.
