Tow vehicle to pull a hybrid
Discussion in 'PopOut (Hybrids)' started by heathermax, Aug 3, 2014.
  1. seigell
    seigell New Member
    116
    Apr 23, 2011
    Consider where you intend to Park / Store this TV before you go hunting for "The Longest One Available". Crew Cabs often only come with the 5'6" Bed, but include a Bed Extender / Cargo Gate. Often a Long Bed Quad Cab or most any 3/4-Ton won't fit into a "standard" 20ft Garage.
    (Heck, I need to dismount the Hitch in order to close the Garage Door on my Ram 1500 CrewCab with it's 5'6" Bed.)
  2. RockyRoo
    6,619
    244
    Jun 8, 2012
    Pretty poor argument really, I've hauled more stuff in the back of a Suburban than you could possibly imagine, most of which you would probably never even consider trying. There are few things that you can't fit if you want to.
  3. yetavon
    3,376
    217
    Mar 11, 2010
    Western NC
    We have a Silverado Ext cab with the 3rd door, works fine for the grandson in a car seat, and adults for short trips, but with 3 teens you will need all the room you can get so quad cab is my suggestion....If you NEED a pickup... avoid the ridgeline, avalanche type trucks. If the bed size double by dropping the tailgate it aint a pickup... [:D]
  4. upwings
    upwings New Member
    30
    Mar 22, 2014
    I'm starting to think that the rear axle ratio plays a role in the ease of towing. My 2012 3/4 Ram did great pulling our new Roo 23ss. Thought it was hard to keep it in 6th gear. I originally went for the 3.73 gears as that is what I had in my 03 Ram 2500. I only had the popup when we got the new truck and was thinking of fuel economy over pulling power.
    I'm guessing alot of the 1/2 Dodge owners have 20" wheels which automatically upgrades to the 3.92 rear end.
  5. 96Rockwood
    96Rockwood Member
    654
    Mar 21, 2008
    Whitmore Lake, MI
    Our half ton has 3.42's and I have to look out 6th gear for everything except out utility trailer.
    My 4 speed 2500HD has 4.10's out back and always will get into top gear no matter what it is pulling and I just have the 6.0L out front.
  6. joet
    5,010
    1,076
    The rear axle ratio does play an important part of towing ease,,,, but just because you have a 3.92 does not mean the final ratio will be lower. Tire size influences the final ratio. When you increase tire size, you raise the final ratio. So your not gaining a lot.
  7. sebring96hbg
    sebring96hbg New Member
    70
    Sep 7, 2011
    We have a Ram 1500 Outdoorsman Crew Cab with the front bench seat. It's a 2013 with the eight speed which pulls our Jayco X23B quite nicely. Ram has a really nice interior and the Outdoorsman model is, in part, designed for campers. The Ram crew cab is spacious, easily accommodating my four kids.
    The higher the rear axle ratio, the better the towing capacity.
    If you have the opportunity to shop for your truck and hybrid at the same time, make sure that the truck has the towing capacity to cover the weight of the hybrid and its cargo as well as the weight of the cargo and passengers in the truck. You might also consider the same for any potential future trailer depending on how many years you intend to keep the hybrid before upgrading.
  8. joet
    5,010
    1,076
    The lower rear axle ratio , the better towing capacity. The higher will give better fuel mileage non towing.
  9. Broncojim
    Broncojim New Member
    18
    Apr 27, 2014
    We solved our TV issues by purchasing a 2005 F-150 crew cab. Lots of leg room in the back seat. Did have a Chrysler Pacifica, 5,000 lb tow capacity. It seemed to handle it OK, PUP weighs 2500 lbs with a full water tank, but I was worried about long term stress on the drive train.
  10. 1380ken
    1380ken Well-Known Member
    2,468
    863
    Nov 7, 2013
    Mass
    I have three kids. Three kids sitting on the same backseat for long rides can be a problem. Even with a full size back seat , nobody wants to sit in the middle. I would look for three rows of seating.
  11. sebring96hbg
    70
    Sep 7, 2011
    Sure, the lower the gear, the better the towing capacity. However, the higher the rear axle ratio, numerically, the better the towing capacity.
    For example, a truck with a 3.92 rear axle ratio will have a better towing capacity than a truck with a 3.21 rear axle ratio.
  12. seigell
    seigell New Member
    116
    Apr 23, 2011
    Sorry, Joet...
    Higher Ratio, more Revs of Engine per Rev of Rear Axle.
    That means Higher Ratio means Better Towing but Lower MPG (towing or not).
    For the RAM 1500, the 3.92 Axle hits a real Sweet Spot - including offering the Only Option for a Limited-Slip Differential (also a real benny for Towing).
    With my 3.92 LS and my 5.7 Hemi, and heavy HW PUP, it means that turning onto an Arterial from a stop on a Side Street sees Chirps out of both Rears rather than full-blown Spinning of the Right-Rear!!
    And with the Hemi's Econ-mode, I sometimes find myself rolling down the I-10 at 70MPH using only 4-cyl (makes a Weird Diesel-like Exhaust Note, but saves a bit on those MPGs).
  13. joet
    5,010
    1,076
    We were always taught than a 4:10 was lower than a 3:55, I have been out of it for a while, curious as to when things changed
  14. 1380ken
    2,468
    863
    Nov 7, 2013
    Mass
    Place a strip of painters tape on the driveshaft and one on the wheel. With someone looking under the jacked up car rotate the wheel and count the driveshaft revolutions and compare. For example 41 rotations of the shaft with 10 rotations of the wheel is 41/10 or approx. 4.10.
    If you were counting the teeth in the pinion gear and the ring gear the same formula works 43 teeth on the ring gear and 11 teeth on the pinion is 43/11 or 3.90 ratio.
  15. bbcute
    bbcute New Member
    Aug 13, 2014
    I just bought a 1991Palamino stx. My TV is a 2007 Ford Escape V6 with AWD. I can't find out how much my pup weighs for sure but no problems driving it home. Should I be anticipating problems? I'm asking cuz I noticed how everyone seems to have more muscle in their TV than mine. Thanks!Deb
  16. mnebinger
    mnebinger Livin' The Dream!
    1,213
    Jul 22, 2012
    Deb, this discussion is about towing a travel trailer, not a pup.
    From what I see online, your Escape has a 3500# tow rating. I don't see a STX, but a SXL weighs 1300+/- lbs.
  17. cfmx
    cfmx New Member
    282
    Jun 21, 2012
    We bought Tundra CrexMax. Lots of leg room for adults in rear seats. Handles our 233S w/ no issues.
