trailer dolly vs tandem axle
Discussion in 'Camper Pre-Purchase Questions' started by Dingit, Dec 16, 2020.
  1. Dingit
    Dingit Well-Known Member
    1,768
    1,246
    Mar 8, 2017
    I'm considering a hybrid at some future point.
    To park it I would have to use a trailer dolly. Is a tandem axle going to cooperate with my dolly? Make it easier? Harder? Or not matter? I'm looking at both single and tandem axle trailers and parkability is a huge concern.
    (I have a geared 5000lb/500lb tw dolly because the Harbor Freight dolly absolutely refused to deal with 3500 lbs of popup on an incline. It's pretty good for small adjustments.)
    Thanks!
  2. Sjm9911
    10,485
    7,821
    No idea, i just know i wouldn't want to do it. Good luck.
    neighbormike and xxxapache like this.
  3. PopUpSteve
    PopUpSteve Administrator
    19,924
    2,777
    Dec 22, 2002
    Malvern, PA
    I tried a trailer dolly and even on a small trailer, it was easier to suffer through using the tow vehicle to get the camper in place.
  4. Dingit
    1,768
    1,246
    Mar 8, 2017
    Haha! Do you think the tandem axle would make it more difficult though? Some of these trailers weigh the about the same as my popup which is dollyable. They're just a bit wider and a lot taller...
  5. xxxapache
    4,056
    2,329
    Sharp turns with dolly on a tandem axle trailer will probably be difficult.
    neighbormike likes this.
  6. Dingit
    1,768
    1,246
    Mar 8, 2017
    So....has anyone actually used a dolly with a tandem axle?
    I do recognize that it'll make sharp turns trickier.
  7. Ladiesman
    Ladiesman Well-Known Member
    754
    540
    Feb 6, 2018
    We use to use one on a tandem axle car but they did not have near the tongue weight of a camper. I cant imagine it would be any fun.
    xxxapache likes this.
  8. flingwing1969
    flingwing1969 Active Member Silver Supporting Member
    614
    169
    Jul 6, 2013
    California Cascade Range
    I have several tandem axle trailers - no TT though. I frequently move them around with my tractor and a special attachment I made on my forks. The tractor has no difficulty moving the trailer, of course, but with a tandem axle trailer, anything other than a very gradual one ends up actually dragging at least one of the tires. My guess is that dolly will have difficulty overcoming the friction created by that dragging tire.
    neighbormike, xxxapache and Jimbow like this.
  9. Dingit
    1,768
    1,246
    Mar 8, 2017
    Thanks guys. I'm anticipating a lot of itty bitty maneuvers rather than big directional adjustments but...yeah...
    Maybe it'll be time to put a hitch on the front of the TV. [XX(]
    1380ken likes this.
  10. LjohnSaw
    849
    57
    Jun 24, 2011
    Northern California
    I made a dolly out of an old cast iron rototiller frame, two wheelbarrow tires and a small electric motor. I have a 18' boat trailer with tandem axles and a bit of tongue weight. I had to do a lot of maneuvering to get it in my garage. The tandem wheels sure did put up a fight. You could make it easier if you had the hitch either really high or low on the dolly to shift more weight to one axle.
  11. Dingit
    1,768
    1,246
    Mar 8, 2017
    Interesting idea, John!
  12. McSkippy
    McSkippy Active Member
    162
    145
    Sep 10, 2019
    Colorado
    If there was a front hitch available for my TV, it would have been on there a long time ago.
  13. Dingit
    1,768
    1,246
    Mar 8, 2017
    It does seem like there'd be multiple uses for it. And it would cost less than replacing 45 feet of roof gutter (my personal parking challenge). :)
  14. Rocket Don
    Rocket Don Member
    64
    41
    Jul 5, 2019
    North Carolina, US
    If the tandem gives you trouble, couldn't you remove a tire on each side? You are only moving slowly and a short distance to get it into your parking spot. That might be a lot of tire mounting/removing but some folks do that routinely as a theft deterrent.
    Don
  15. Dingit
    1,768
    1,246
    Mar 8, 2017
    Another interesting idea. Obviously I have no idea. :)
    Was it the Aristocrat trailers that used to come with a set of tiny metal wheels so you could fit the thing into the garage? There used to be so much creativity in the RV industry.
  16. michigan_camper
    michigan_camper Member
    62
    Aug 16, 2016
    I bought the Trailer Valet I think it's called. Very expensive. I have a tandem axle popup (HW296). Overcoming the tandem axle is very difficult even with the dolly. Here's a tip: I put a large piece of cardboard under both sets of tires as I moved it into the garage. Once it was unhooked from my vehicle, my wife and I were able to shove the camper from side to side because it would slide on the cardboard. I quit using the dolly and would like to sell it now. It was over $600 and I believe they cost even more now. The dolly would move the camper under normal circumstances, but if you're trying to wedge it into place or make short sharp turns, its not much help.
  17. Dingit
    1,768
    1,246
    Mar 8, 2017
    Thanks, MI camper. That is the exact info I need. That's the dolly I have and it's pretty good for getting my fat single axle around.
  18. Speckled_Tiger
    Speckled_Tiger New Member
    Dec 27, 2020
    Rik Peery likes this.
  19. WrkrBee
    WrkrBee Un-Supported Member
    6,447
    3,381
    Are we talking about parking it on a concrete pad, in a garage, in a yard, or at a campsite? Surface type will affect answers.
  20. Dingit
    1,768
    1,246
    Mar 8, 2017
    Paved, very narrow sideyard where inches make a difference. I can't do it with my TV. I just don't have the skills. You probably do. I don't. :)
    I know that the dolly is capable of putting a single axle trailer in the spot, probably because it's slow.
