Trailer wiring for 2007 Ford F-150
Discussion in 'Tow Vehicles, Hitch & Towing' started by malaki86, May 16, 2013.
  1. malaki86
    malaki86 New Member
    90
    Apr 11, 2013
    My truck, a 2007 Ford F-150, already has a 4-wire connector on it (it's a Reese T-connector). That was all fine and good until I bought my "new" camper. This one is a 6-wire (adds 12v constant power & backup lights) - the camper has surge brakes. I know the truck is somewhat setup for a full 7-wire system because there's a fuse in the fusebox for camper fuses (electric brakes & 12v power).
    Someone told me that there's a plugin at the rear of the truck for a standard 7-wire system. I just need to buy the plug adapter from a parts store. I found the adapter with no problem, but I can't find the plugin on the truck anywhere.
  2. chrismarques
    chrismarques New Member
    246
    Jun 24, 2006
    The connector your looking for is over the left side of the rear axle. Ford makes a nice expensive connector to plug in with a 7 wire plug at the end. When I wired up my '08 f 150 it was going to be about $95. Search on etrailer for a video on hooking up a brake controller on your year truck and they show how to tap into that wiring without having to buy the ford harness. Also you may have to plug a relay in the fuse box for the 12v to be live.
  3. arthuruscg
    arthuruscg Active Member
    1,363
    Nov 14, 2012
  4. malaki86
    malaki86 New Member
    90
    Apr 11, 2013
    When I called the local Ford dealer, they quoted me $135 for the harness. Pretty steep.
  5. malaki86
    malaki86 New Member
    90
    Apr 11, 2013
    Found the correct one @ eTrailer. Thank you all!
