I just bought a 93 Colman Pioneer Chesapeake popup from a person from Ohio. Before i can get it title and plates in PA i need to know the Unladen weight of the popup is. I've looked online in the manual etc can't find out what it is does anyone know were i might find such info at?
There should be a sticker on the tongue or on the side of the pup. There also should be a paper labor glued to the inside of one of the cabinet doors. Did you get a title or registration? The EW, empty weight, or unladen as they ask should be on that.
on the side of the popup it has GVWR 1995 GAWR 1810 i'll check in the cabinet I got a ohio title but the weight isn't on it for some reason
is there a way i can print out the specs from the manual pdf file so i can show the person that is doing the transfer? i tried to click on it and save just that page and print it out and it said it was password protected.
Go here, http://www.popupportal.com/MGalleryItem.php?id=2992 and use Control+P and print a single page. The actual page is 59, but you want to print page 63.
Ummmm......isn't there a title for it? You should just have to have it signed and notorized that you purchased it, go to a tag place in PA and get a plate for it. The only time I had a PIA time getting a plate for a trailer was for a homemade trailer without a title.
