Traveling with full water heater and toilet tanks
Discussion in 'First Time & New Camper Owners' started by John the Baptist, Nov 7, 2019.
  1. John the Baptist
    John the Baptist New Member
    Aug 22, 2017
    Hi- does it hurt anything to wait until I get home to drain the water heater and Thetford toilet tanks?
  2. xxxapache
    2,881
    877
    Nope
  3. bheff
    bheff Well-Known Member
    882
    415
    Feb 24, 2011
    NW Arkansas
    Nope....most dont drain the water heater until the end of the year. The cassette toilet gets dumped at the camp ground.
  4. Snow
    10,137
    1,047
    Only time my water heater gets emptied is at the end of the season when winterizing or spring when I'm sanitizing the water system.
    WVhillbilly, xxxapache and bheff like this.
  5. kitphantom
    11,758
    857
    Depends on how your camper tows with water on board. Our small TT does fine, so we do travel with water in the (20 gallon) fresh tank and hot water tanks, as well as in the waste tanks if we can't dump until somewhere on the road or even near home. Of course, by the time the waste tanks are full, or nearly so, the fresh tank is close to empty.
    We do drain and rinse our hot water tank a couple of times a year, because our water is very hard and it seems to produce a lot of grit. (The anode has worn away some, but is in far better condition than I expected by now.)
  6. Dingit
    Dingit Well-Known Member
    880
    409
    Mar 8, 2017
    We are usually self-contained from the time we leave until we return because we rarely encounter a dump station. So 20 gallons fresh/grey (depending on how far along we are), and whatever is in the toilet and water heater.
    Carrying water probably makes me exceed my popup's max weight rating...
  7. BillyMc
    BillyMc Well-Known Member
    1,143
    525
    Mar 25, 2018
    I do it often.
  8. Fixitup
    Fixitup Active Member
    387
    225
    Jun 7, 2016
    I drain and flush h/w tank at the end of each trip.
  9. Econ
    Econ Active Member
    311
    116
    Aug 18, 2019
    Deep South
    Water is 8.35 pounds per gallon. If your are carrying 20 gallons as some above state, that is 167 pounds of extra weight. You could just unscrew the plug and walk away at camp as you leave.
    Depends on where the water is. We are definitely nose heavy so I put some in the tank to lighten the tongue weight.
  10. xxxapache
    2,881
    877
    With my TT, I always leave home with 52 gallons in the FW tank, 6 gallons, in the WH and 3-5 gallons in the black tank. The trip back is usually close to that. My TT towing trucks are stout enough that I don't have to crunch the weight numbers.
    neighbormike and BillyMc like this.
  11. BillyMc
    1,143
    525
    Mar 25, 2018
    If I have to crunch numbers so tight I have to worry about a couple hundred pounds of anything it's time to upgrade the TV or downsize the camper.
    Toedtoes and xxxapache like this.
  12. Dingit
    880
    409
    Mar 8, 2017
    My TV doesn't care about the weight but my popup probably does.
    Econ and bheff like this.
  13. Toedtoes
    Toedtoes Well-Known Member
    1,700
    1,337
    May 28, 2018
    Neither the water heater tank nor the cassette toilet will hold enough to create an overweight issue. If they do, then you are far too close to your limit than you should.
    As for harming anything - no. They are meant to do just that. No requirement to empty immediately unless you want to use the toilet and it's full or you are winterizing.
  14. Dingit
    880
    409
    Mar 8, 2017
    Yes, we are too close to the limit. It came from the factory that way. :)
    I'm sure John's modern Starcraft will be fine. And the potty will empty better after the contents have jiggled all the way home. :D
  15. Toedtoes
    1,700
    1,337
    May 28, 2018
    Dingit - the fresh and/or grey/black tank could be enough to go over the limit without adding anything else in the trailer - the manufacturers build them purposely this way assuming folks will always use hookups.
    But the 5-6 gallons in the water heater and/or the few in the toilet should not be enough to go over the limit before adding anything else (including water in the other tanks).
