Tried a different cast iron seasoning method
Discussion in 'Pots, Pans, Grills, Other Cookware / Cleaning & Fo' started by kstephens, Nov 15, 2016.
  1. kstephens
    kstephens Member
    242
    Jul 28, 2014
    Usually stick to crisco and bake off. However, I got a brand new cast iron pan (Lodge), and while it seems good, I was not confident in the "pre"seasoning, and thought I would give a different method a try. While researching I came across this article for using Flaxseed oil....
    http://sherylcanter.com/wordpress/2010/01/a-science-based-technique-for-seasoning-cast-iron/
    I though I would try this but after one round in the oven at 400 - I wasn't fond of the smell. I did the next five on the grill - keeping the temp around 450 for an hour or two, and then cool off. Yes, 6 cycles of this - just wanted to see if it is all it was cracked up to be. It seems to be the most durable seasoning I have put on one, and one of the more non-stick from the first cook. This will be my new method for all re-seasoning - just need a free weekend and I am going to do my dutch ovens.
  2. Orchid
    Orchid Sharp Shootin' Grandma
    5,661
    2,493
    May 8, 2011
    Florida by way of WV and MD
    Where did you find the flax seed oil?
  3. MileHigh
    MileHigh Active Member
    456
    52
    Jul 18, 2012
    Denver
  4. Orchid
    5,661
    2,493
    May 8, 2011
  5. silvermickey2002
    4,756
    532
    Sep 11, 2008
    Morris County, NJ
    I use the Lodge Seasoning Spray, so far so good...
    https://smile.amazon.com/Lodge-A-SPRAY-Seasoning-Spray-8-Ounce/dp/B00J9QVVG8/ref=sr_1_1?ie=UTF8&qid=1479263066&sr=8-1&keywords=lodge+seasoning+spray
  6. kstephens
    kstephens Member
    242
    Jul 28, 2014
    I found it in the organic/fridge section of our grocery (Kroger). It was $8-$9 for an 8 oz. bottle. However, I used very little when seasoning -no more than an ounce on a 12" pan total for all 6 coats - a teaspoon per coat and wiped out thoroughly before heating. I am thinking I can get through my 2 dutch ovens - and probably still have enough to repeat a couple of those. I don't see the price as unreasonable, especially if it really is more durable than traditional seasoning.
  7. hotrodcamper
    hotrodcamper Member
    972
    Nov 3, 2012
    X2 on the Lodge seasoning spray. So far I'm happy with that.
  8. yetavon
    3,371
    216
    Mar 11, 2010
    Western NC
    Have used it....but read the label...its just 100% canola oil
