Truck wiring to charge camper battery?
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Allan Unger, Nov 13, 2019.
  1. Allan Unger
    Allan Unger New Member
    Oct 19, 2019
    Colorado
    I have a 2007 Tundra with a 150 amp alternator. The camper is a 1994 Scamper PUP. I want to wire the truck to charge the camper battery (there is no battery currently installed on the camper). What is the best place to locate the battery in the camper? What gauge cable should I use? What is an appropriate isolation solenoid to use for this configuration? Appreciate any responses!
  2. Raycfe
    15,255
    1,453
    Usually on the tongue of the camper. Too much weight in the rear leads to sway. 10 gauge wire.
    davekro likes this.
  3. rabird
    6,709
    304
    TX
    Check your Tundra for an existing charge line!
    I used a 40A 'short stop breaker' (auto parts store) @ the batt+, 10g (8g would be better), plastic loom to protect the wire and zip ties to keep it in place along the run to the rear.
    I found a fuse holder (hot with ignition) not being used (sun roof), added an 'add a fuse' and wired a relay to turn on/off with the key. With the add a fuse you can add a circuit to almost any existing fuse.
    Allan Unger likes this.
  4. Anthony Hitchings
    487
    164
    Mar 2, 2019
    There is a lot of info on your questions on this site and on the web, especially discussing wire gage. Isolation solenoid is an essential part of the system.
  5. Anthony Hitchings
    487
    164
    Mar 2, 2019
    Since you asked about wire gaqe, let me toss this out to the active readers, purely as an FYI. A while back I bought the OEM 7-pin harness for my 200 Jeep Liberty. I have not installed it. I have looked it over a few times, and the wire gages are quite small, even the largest is nothing close to 10 GA, or even 12 Ga. Its most surprising. Ditto the wire gage on the back of the "cigarette lighter" outlet on the front dashboard. Heading in the opposite direction, the alternator on my 1969 Chevy V8 was 55 Amps, the alternator on my 2008 Liberty is 140 Amps. Loads are the same being engine, lights and AC unit.
  6. GreyFox
    GreyFox Well-Known Member
    1,409
    662
    Oct 10, 2018
    S Ontario
  7. tombiasi
    5,344
    983
    Some people think they need a very large gauge wire to charge the battery. You only need the same gauge as the OEM charge line. Maybe if you were going to run the line a hundred feet you would need heavier wire.
  8. Anthony Hitchings
    487
    164
    Mar 2, 2019
    My guess is that there are two scenarios for a TV charging the Pup's battery:
    1) Maintaining charge or light charging of the PUP battery (PUP voltage is not low) - smaller gage is ok, voltage drop in the charging line is not too big a deal
    2) largely depleted PUP battery - you either need heavier wire gage to minimize voltage drop or get a longer charging time - but be careful of overheating the wiring or connectors in the TV. Auto alternators are designed for auto use (voltage-wise) , so they likely won't offer as much voltage to your depleted PUP battery as a stand alone or PV charge controller, this situation, to a degree, limits the current (as current = function of voltage difference) in the charging line from the TV. Which is likely why some folks say you can't run the 3-way frig and recharge a depleted battery at the same time while towing a PUP.
  9. rabird
    6,709
    304
    TX
    OEM 16g is not adequate. Voltage drop is the issue over 20 feet or so even at 10A.
  10. tombiasi
    5,344
    983
    Vehicle alternators are not designed to charge a dead battery, they are designed to maintain them.
  11. tombiasi
    5,344
    983
    Do you know of a vehicle that uses a 16 Ga. charge line? If so 8 Ga. wire after that will do no good.
  12. rabird
    6,709
    304
    TX
    Yes, my 2015 ford truck, wired just like the '16 in the video. One does not use the dinky charge line, one rewires with ample size wire all the way to the battery.
    On my S-10 with no charge line I added as stated above, the 4 to 7 blade adapter did have 10g wire for Aux, 12v- chassis common and 12v+ charge line.
  13. tombiasi
    5,344
    983
    Surprised to hear that but I do agree with your solution.
  14. Econ
    Econ Active Member
    325
    117
    Aug 18, 2019
    Deep South
    IF, you believe in operating the 3 way refrigerator on 12 volt while traveling, The charge wire on most is too small to supply enough to keep from depleting the camper battery. If, you come over and join the dark side, you can use propane. Join the dark side, we have candy.<GG>
  15. Allan Unger
    Oct 19, 2019
    Colorado
    jgdurbin likes this.
  16. Allan Unger
    Oct 19, 2019
    Colorado
    After some more research, I found that my factory 7pin connector has a 30A, 12V Pin. Would this be adequate to supply voltage to the camper battery, provided that the wire is at least 12 ga?
  17. tombiasi
    5,344
    983
    For 30 Amps you should use 10 Ga.
  18. GreyFox
    1,409
    662
    Oct 10, 2018
    S Ontario
    Regardless of wire gauge your vehicle will never be able to fully charge a discharged deep cycle battery as it's incapable of supplying an adequate bulk charging voltage of at least 14.4 volts and for a sufficient length of time - it was never designed for this purpose. The solution, as I mentioned earlier, is to equip the vehicle with a DC > DC charger which is specifically designed to overcome this issue.
  19. tombiasi
    5,344
    983
    True.
  20. rabird
    6,709
    304
    TX
    Yes, that will work as well as many others. No it will not fully charge a battery. I know nothing of you computer's way of regulating alternator voltage, but you should get some charge to the battery just don't expect too much!
    So add a battery tray to your tongue, add a battery, wire the batt+ into the trailers 'charge line' that goes from the trailer/TV connector to the back of the power center, fuse this at the battery, wire the 12v- to chassis common IE the frame of the trailer (certainly not earth ground). Buy a few feet of 10g in red or black for the + and white for the -.
