Try and stop me...
Discussion in 'Introduce Yourself' started by b_young, Jun 11, 2019.
  1. neighbormike
    2,384
    1,804
    Oct 6, 2012
    WI
    Lots of threads here about roof rebuilds! Good luck!
  2. Orchid
    Orchid Sharp Shootin' Grandma
    5,372
    2,102
    May 8, 2011
    Florida by way of WV and MD
    If the a/c works, that's worth $500 - $600 alone.
    I've seen some absolutely amazing transformations around here. Pop ups are easier to transform than travel trailers. Make some individual threads or a rebuild thread for it and I'm sure you'll have plenty of help. :)
  3. Ranger3318
    Ranger3318 New Member
    Jun 23, 2019
    Freeport, IL USA
    I know what you mean. I'm in the midst of fixing up an old 1990 Coleman pup
  4. G T
    G T Member
    75
    Aug 19, 2019
    Florida Panhandle
    Removed the vinyl flooring from the cargo department and found black mold. Also removed the plywood veneer that was wet and swelled. Now that I can see what needs to be done will be adding a hardener to the particle board floor and MDB walls then I will seal it in and waterproof everything. This time though I will be adding a drain hole so water can't stand if it does get in there.
