TV Jack Sufficient?
Discussion in 'First Time & New Camper Owners' started by andosfauxtos, Oct 19, 2019.
  1. andosfauxtos
    andosfauxtos Member
    40
    Aug 12, 2019
    Hi all,
    I'm trying to figure out if my TV's jack is sufficient to use with my PUP. I'm guessing it is, but wanted to ask the experts what you think. My TV (2006 GMC Envoy) has a GVWR of 5750 lbs and came with a jack. My PUP (1999 Coleman Nevada) 2131 lbs (max weight loaded is 3k-ish, but I'm sure I'm not close to that even when it is all loaded).
    So, my TV jack should be enough to lift it to change a tire and such, correct?
    I will have to get a different lug wrench, as the lugs on the TV and PUP are different sizes, but I think I can at least save myself from having to buy another jack.
    Thanks all!
  2. bheff
    bheff Well-Known Member
    845
    394
    Feb 24, 2011
    NW Arkansas
    You'll be fine. Remember you will only be lifting one side so the weight is much less than the whole trailer.
    I carry a battery powered impact with corresponding sockets for the Tow vehicle and trailer. Also have a 3/4 inch for my stabilizers with an adapter to use with a drill.
    andosfauxtos likes this.
  3. tombiasi
    5,311
    955
    Your TV jack is more than qualified but it has to fit under the camper.
  4. andosfauxtos
    andosfauxtos Member
    40
    Aug 12, 2019
    Ooooh, good point! I should probably check that. Thanks!
  5. tombiasi
    5,311
    955
    Yes you should and you are welcome.
  6. mv520
    mv520 Member
    585
    May 2, 2010
    And don't forget it has to fit underneath the PUP when the PUP tire is potentially flattened, so assuming you test with a fully inflated PUP tire, make sure there is a 5" (or whatever your PUP tire sidewall height is) gap between the top of the lowered jack and the frame/axle/etc. jacking point(s)!
    BillyMc and PointyCamper like this.
  7. Sjm9911
    4,467
    2,285
    That and wood blicks to support it, or make up the difference in height if needed. Not every flat is on a level surface.
  8. Snow
    10,104
    1,027
    Depends if the head of the jack is designed to fit in a notch under the vehicle.. many uni body jacks are designed this way (no idea if your Envoy is unibody or full framed but even full framed it may have a head to fit a specific spot GM like doing silly things like that) .. Also check and make sure the vehicles lug wrench fits the trailer..
    PointyCamper likes this.
  9. andosfauxtos
    andosfauxtos Member
    40
    Aug 12, 2019
    I'll have to check the jack head to see if it will work, thanks. I checked both lugs in both my vehicles, neither fits so I'll have to get a new one for the PUP.
  10. MsMac
    MsMac Well-Known Member
    589
    255
    May 19, 2016
    My partner swears by our floor jack for all of our jacking needs. :) He says that it's far easier to use, more versatile and more stable than the jack that came with our truck. We use it not only to change tires on the trailer and our vehicles, but also to lift the tongue of the trailer, or the back end, when we put the stabs down on uneven ground. The only downside it that it's rather large and heavy (ours is on the small side and still is about 15-20 pounds), so storage might be an issue for those, unlike us, who have passengers in the backseat often and can't use the floor there for storage.
    We also use a star wrench for tire changes. It has the 4 most common lug sizes and eliminates the need for any power tools to tighten the lugs.
    1380ken likes this.
  11. Balthisar
    Balthisar Active Member
    300
    156
    Jun 26, 2018
    Plymouth, MI USA
    I have a floor jack at home that's super fast to use; I'd never use my TV's jack at home, because it'd be a PITA. I did use my TV's jack this past weekend, though, because I let my tire blow on my way home. Given the choice to carry another jack on 100% of trips or to use my TV's jack on 1% of trips, I'll choose to use the TV's jack on 1% of trips.
  12. WrkrBee
    WrkrBee Well-Known Member
    2,448
    936
    I found out the hard way, that my TV (1997 F150) jack only had a stroke of 6". It may be more useful on a camper, but not on a high sidewall light truck tire. I bought an 8 ton bottle jack with a double ram that has a 16" stroke. It goes on every camping trip.
    WVhillbilly and Sjm9911 like this.
  13. Dingit
    Dingit Well-Known Member
    866
    398
    Mar 8, 2017
    ...i should look into this. Thanks for the reminder....
    Rik Peery likes this.
  14. p
    p Active Member
    531
    119
    Jun 9, 2014
    ...and....remember that the bolts holding the spare are different size compared to the mount.
  15. Jaygray
    Jaygray New Member
    Jun 7, 2019
    I picked up an aluminum racing jack at Harbor Frieght. I think it was $69 but I can’t remember if that was before or after their always available 20% off coupon. Best money I ever spent! 4 pumps and the tire on whatever vehicle I happen to be near is up in the air on under 15 seconds! It stays in the back of the Tacoma but has been a lifesaver a half dozen times over the years. Of course it raises the pup tires with no effort whatsoever. Couldn’t even tell you where the factory jack is stored in the Tacoma and I’ve driven it over 100k. Best guess is under the back seat.
  16. Lumbergodd
    Lumbergodd Member
    85
    50
    May 20, 2016
    I have a small bottle jack that I use for the camper. I store it in a box on the tongue, along with chocks and a 4-way wrench. This way I don't have to unload my TV to get to the TV jack.
  17. BillyMc
    BillyMc Well-Known Member
    1,096
    496
    Mar 25, 2018
    The jack from my F-150 works fine. Some jacks that use the lug wrench to raise them my be a problem getting in a place suitable for lifting and still be able to turn the wrench. I'd recommend testing before you are on the road with a flat and no way to lift the PUP. A quick lift jack is great for some trailers, but can't find a place I'm comfortable using it with the torsion axles on our PUP.
