two six volt batteries hookup question
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by scootit, Nov 9, 2016.
  1. Jughed
    Jughed Member
    250
    Aug 14, 2015
    It sounds like a negative/ground problem for the jack.
    Check all possible (-) connections & cable for any signs of corrosion, loose connections.
    You are getting power to the unit - a quick shut down like you indicated is a typical symptom of a bad or no ground.
  2. scootit
    scootit Member
    46
    Feb 16, 2016
    Thanks everyone. I had to connect the power jack positive wire to the positive on the battery on the right side. That battery had the positive that connected to the trailer. Next is to connect solar panels.
  3. wecamp
    wecamp Member
    152
    Sep 28, 2006
    Grosse Pointe Park, Michigan
    Glad you got it working. I am jealous that you are camping this weekend. Our camper has been winterized for a month. Make sure you use a charge controller with your solar panels.
  4. rabird
    6,919
    399
    N. TX
    Charge and load connect to same spot so the wires from the solar controller go to the same spots as the trailer!
  5. scootit
    scootit Member
    46
    Feb 16, 2016
    Everything is going great with the new 6 volt batteries. Having two of them gives us the power we need. Now I need to keep them charged. Do I buy a 3 stage charger to use on the 6 volts? I can charge by plugging into my house but will it give me a full charge and not over charge it? If I understand it correctly...a 3 stage can stay on my batteries and I don't have to worry. Any one out there use 6 volt batteries and can help me with this?
    Thanks
  6. tombiasi
    5,687
    1,312
    Please forgive me but I think yo need to adjust your thinking.
    You do not have two batteries, electrically you have a 12 volt battery. The cells that make up the 6 volt batteries are combined to make one battery of cells. Charge them as a 12 volt battery.
    Maycat likes this.
  7. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    "Battery"
    noun, plural batteries.
    1.
    Electricity.Also called galvanic battery, voltaic battery. a combination of two or morecell electrically connected to worktogether to produce electric energy.cell1(def 7a).
    2.
    any large group or series of related things:
    a battery of questions.
  8. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    Boo to copy/paste
  9. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    You have two cases with 6 cells each. All twelve cells in series is what is known as a "battery"
    More importantly, the way you describe your troubleshooting methods scares the bejesus out of me. Please invest in an electrical meter and a couple of YouTube series on low voltage electrical theory
    Campers (most *especially* popups) burn fast. Real fast. So fast you won't know what happened. Respect the electricity.
  10. Customer
    Customer Well-Known Member
    2,435
    244
    Jun 5, 2014
    It depends, what is the brand and model of your converter?
