UAV-TT off-road build
Discussion in 'Checkout My Rig !' started by Silvrzuki77, Aug 8, 2014.
  1. Silvrzuki77
    Silvrzuki77 New Member
    108
    Aug 1, 2014
    Alright key item showed up today!!!!
    Lock n roll is awesome! They got this out quick!
    Called my dad up to come watch the kids while I got to work! Got the hitch welded on nothing special.
    Than!
    Test drive time!!!! Did quite a few laps around the neighborhood. Got the e brake controller set. Off to the freeway! Braking was great pulling was great! Hit 85 mph zero pull, sway, or serious issues!!!
    Stoplight photo!
    Issues i did have....
    Too much air in the bags.
    Had body sway when i rocked the steering wheel back and forth at speed.
    Solutions....
    Less air in bags
    Heavier valved shocks or build a different shock tower(worse case)
    Going to get another set of bump stops that are not cut. My hummer actually barely touches the front bump from the factory. The blazer bump stops I have are super squishy.
    Hope to get a full day of work sunday and knock alot of stuff out
  2. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    sweet! Keep the progress pics coming!
  3. yetavon
    3,376
    217
    Mar 11, 2010
    Western NC
    Awesome work.....
    Did you get any camping movies?(Sorry couldn't resist)
  4. Silvrzuki77
    108
    Aug 1, 2014
    Haha!!!! Was wondering when someone would see that!
  5. xgromx
    xgromx 1984 Sun Valley
    22
    May 18, 2008
    Good stuff, haha
  6. Silvrzuki77
    108
    Aug 1, 2014
    Moving along original trailer A frame was cut off today. Man do I love have a plasma cutter!
    Have to go in a cut off the rest did want to torch the body. Should have the majority of it done sunday.
  7. dcbain
    dcbain New Member
    342
    Apr 28, 2014
    The next best thing is what we have - an enthusiastic neighbour with a plasma cutter!
  8. Silvrzuki77
    108
    Aug 1, 2014
    Well got all the big stuff done!
    Winch installed
    Beside my battery being low it worked good
    https://vimeo.com/110092844
    Got my landing leg installed and reused the old propane/battery mount installed. Eventually when I add dual batteries I will build something nicer[​IMG]
    Need to extend the bed support legs to fit the new mounts and add a top cap to give a cleaner look
    Painted and getting close
    To do list at the moment
    Tidy up the wiring
    Paint fenders and install fender trim
    Paint the frame and trailing arms
    New shocks
    Build a rear bumper setup
  9. lifespeed
    lifespeed Member
    693
    Aug 26, 2014
    Is that a rod end instead of a standard coupler to a 2" hitch ball? Is it for articulation off road?
  10. Silvrzuki77
    108
    Aug 1, 2014
    The hitch is from Locknroll.com . Yes it is for articulating offroad very sweet!
  11. lifespeed
    lifespeed Member
    693
    Aug 26, 2014
  12. Silvrzuki77
    108
    Aug 1, 2014
    That's a really old video and they have made several newer versions since than. They fixed the binding issue in the newer setups.
    http://youtu.be/pK99NpixLFI
    http://youtu.be/doGGK-DBrzw
  13. Silvrzuki77
    108
    Aug 1, 2014
    Finished up my wiring today. Got a safety on and off switch installed for the winch for stray signals. Rare it could happen but what the heck. Started working on the rear bumper. Super simple with ammo can storage.
    Here are the bolt ammo cans locations. Had wanted them to open on top, but with the stabilizers and bumper brackets this is the only option. Will fix them to hinge downward.
    Figuring I will run a spare tire off the back along with a high lift.
    Planning on camping in the backyard tonight, of course 30-40 mph winds.
    Oh my Merica knitted beer cozy!
  14. dcbain
    dcbain New Member
    342
    Apr 28, 2014
    After all you've done over and above the original pup shouldn't the body graphics read "SILVRZUKI77 with a little input from Starcraft"?
  15. Silvrzuki77
    108
    Aug 1, 2014
    Lol feeling that way!
  16. Silvrzuki77
    108
    Aug 1, 2014
    Did a little more today.
    Switched shocks out. Not to impressed think I will need to redo my shock mounts. Probably go almost 90 degree mount should help out. Going to test drive it first though.
    Worked on my rear bumper setup. Ammo cans were welded and mounted
    Threw the spare tire on to get a feel. Hangs below the bumper but is still higher than everything else just looks weird.
  17. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    Your welding and fab skills are awesome! Maybe I'll see you pulling it in Vegas. What a great build!!!
  18. Silvrzuki77
    108
    Aug 1, 2014
    Worked on my bumper, little plasma cutting and drilling.
    Looks off center soo the hummer cap can fit straight.
    Replaced my batter with a grp 29 deep cycle. Has 119 Ah same one I had in my teardrop. Also picked up a small impact just for the camper legs at harbor freight. Once I get my replacement bag not much left to do really.
  19. Silvrzuki77
    108
    Aug 1, 2014
    Got to take the trailer out last weekend. Was my shake down first camping trip! Soo far performed flawless! Need to get OBA system and install a larger water tank for sure! Would like to get a big buddy heater versus using the built in furnace which is loud. Some pics
    [​IMG][​IMG][​IMG]https://vimeo.com/113422199
  20. xgromx
    22
    May 18, 2008
    Looks great!
    Do you have your stabilizer jacks installed and can you put some pictures of them and how you have them setup? I am going to need to do something to my SOA popup, they needed to be replaces and are now too short. Looking for ideas. I do like the angled vs the strait up and down jacks.
