Underside of the Popup?
Discussion in 'Miscellaneous Repairs & Maintenance' started by Fshrmon, Jan 9, 2020.
  1. Fshrmon
    Fshrmon New Member
    27
    18
    Sep 4, 2019
    47.9790° N, 122.2021° W
    Greetings.
    I was crawling around under my Pup just inspecting it and realized that the wood is uncoated. It looks like just straight MDF board and I'm wondering about the rains of the PacNW that we experience out here. Chatting with some friends they recommended using Flex Seal and coating the undercarriage with that stuff, but I'm wondering if there is a different solution.
    Any ideas or suggestions?
    Cheers.
  2. Sjm9911
    4,696
    2,447
    Its ment to be uncovered so it can breath i think. Sealing it will rot it out fast.
  3. gladecreekwy
    720
    809
    Sep 25, 2016
    Jackson Hole
    Many threads on this topic. Not recommended
  4. GreyFox
    GreyFox Well-Known Member
    1,484
    715
    Oct 10, 2018
    S Ontario
    Unfortunately your friends don't know what they're talking about. :rolleyes: Your floor needs to breathe and it can't do that through the top side which has vinyl flooring over it so it can only do so through the underside. You're looking for a solution to a problem that isn't ... leave it as is, it'll be fine. [A]
  5. Raycfe
    15,397
    1,573
    NO FLEXSEAL!!!! the wood needs to breathe.
    The only place flexseal should be is inside a trash can.
    kcsa75, bheff, durhamcamper and 2 others like this.
  6. Wrenchgear
    3,286
    576
    Aug 5, 2010
    5 Star Eagle Camper
    Don't do it!! Leave it alone!!!
    (Just in case the other 4 posts were too vague)
  7. Snow
    10,183
    1,089
    If you want to cover the underside of the floor DO NOT use flex seal , as mentioned only use for that crap is inside a garbage can. Use plastic ore sign material screwed to the frame and enclose the entire underbelly like TT's, 5'ers and MoHo's are.. if you don't want to do that, then leave it alone and stop listening to friends who even suggest flexseal.
