uneven tire wear
Discussion in 'Tires / Brakes / Bearings / Axles' started by Eric Lewis, Aug 12, 2019.
  1. Eric Lewis
    Eric Lewis New Member
    Aug 12, 2019
    the tires on my 2011 ranger wear unevenly on the inside . are ther any adjustments that can be done to the suspension to rectify this ?
  2. WrkrBee
    WrkrBee Well-Known Member
    2,681
    1,039
    Check tire pressure. Same on both sides?
    Jack up the wheels, one at a time, and check for bearing play.
    Torsion axle rubber inserts can weaken / fail losing the needed wheel support. Check while jacked up.
    Is the camper over loaded?
    Measure from a center point on the tongue, back to a point on each side of the axle. Makes sure the axle has not shifted on one side.
  3. bheff
    bheff Well-Known Member
    1,026
    520
    Feb 24, 2011
    NW Arkansas
    If it is a straight axle with leaf springs then you may have a bent axle if your air pressure and load limits arent out of whack
  4. WrkrBee
    2,681
    1,039
    Now that I reread it, are we talking a camper or a truck? Looks like you joined today. Welcome to the Portal from South Carolina.
    If it's a truck, have the front end aligned.
    bheff likes this.
