Unistrut roof brace
Discussion in 'Roof/Floor Repair & Maintenance' started by Matt Benoit, Apr 27, 2018.
  1. Matt Benoit
    Matt Benoit Well-Known Member
    545
    341
    Jul 30, 2017
    Warren, MI
    The unistrut is the more heavy duty version from home depot.. I believe there were 2.
    Are you referring to the 14x14 picture frame i made to raise the AC up 3/4in? I don't have any pictures of the that.. But it's simply a pice of 1x2 pine, that i made into a box. I used silicone between the box and the roof, and screwed it down. Then used eternabond on to completely water tight the joint.
  2. rob87
    rob87 New Member
    May 19, 2020
    Yes the 14x14 picture frame. That works. You used pointed lag bolts to go into the existing wood right?
  3. Matt Benoit
    545
    341
    Jul 30, 2017
    Warren, MI
    On the picture frame i just used wood screws. There was a similar wood picture frame for the structure of the roof. I just screwed mine to it. The unistrut was attached to the side boards using nuts and bolts.
  4. rob87
    rob87 New Member
    May 19, 2020
    So you went through the actual roof to bolt everything down?
  5. Matt Benoit
    545
    341
    Jul 30, 2017
    Warren, MI
    Be specific. Are you talking about the other picture frame again? If so, then i screwed it down.
  6. rob87
    rob87 New Member
    May 19, 2020
    Trying to figure out for mounting the unistrut yo the ceiling and sides. I have pointed lag bolts, but did you use nuts and bolts and if so how?
  7. Matt Benoit
    545
    341
    Jul 30, 2017
    Warren, MI
    The unistrut is bolted through the side walls using a 90 degree bracket. One bolt on each end of the unistrut. Only 4 bolts attach the unistrut to the side boards. As long as your side walls aren't rotten, they will support the weight. They already carry the weight of the entire roof and air conditioner. Look back at the pictures, if you zoom in you can see the bracket at the end of the piece of unistrut
  8. rob87
    rob87 New Member
    May 19, 2020
    Ok. And for the center braces, the smaller ones they are tied in with a nut and bolt into the longer pieces of unistrut, correct? Once again I greatly appreciate your help.
  9. Matt Benoit
    545
    341
    Jul 30, 2017
    Warren, MI
    Those cross braces (the small selection of unistrut) are attached to the longer sections using unistrut hardware. It's a nut with a spring that fits inside the channel. The flat bracket ties them together.
  10. Collin Carroll
    Collin Carroll New Member
    Jun 25, 2020
    Naples FL
    Thanks for all of the information OP. I think I’m going to give this a try on my old ABS roof. The exterior ABS is all gone, but I think I can use this method even with the foam. The outside is getting a few coats of GG. I’m worried about shipping the interior abs plastic that’s peeling seeing there isn’t much else to the roof. I like your idea of the plywood to clean up the interior. Do you think I could do this? I have an 2000 bayside which I’m sure had a different roof make up then yours.
  11. Matt Benoit
    545
    341
    Jul 30, 2017
    Warren, MI
    I can't comment on whether or not you could use the plywood for the ceiling inside. My roof structure has wooden cross bracing that i was able to use to attach the plywood.
  12. Amanda Fransen
    Amanda Fransen New Member
    Oct 16, 2020
    We're there any videos you watched that were helpful?!
  13. TopherRon
    TopherRon New Member
    May 20, 2021
    Hi Matt - really appreciate all this info! When you say you bolted through the side walls, did you drill a hole all the way through your sidewalls and then bolt it and seal around the bolt head?
  14. Matt Benoit
    545
    341
    Jul 30, 2017
    Warren, MI
    Sorry for the late reply, not on the forums much anymore. To answer your question, yes I bolted completely through the side wall. Each bolt was sealed with paintable caulk, but you could use dicor or whatever you want. I painted the pup afterwards so I picked something I knew I wouldn't have any issues with.
    TopherRon and Sjm9911 like this.
  15. TopherRon
    May 20, 2021
    Cool - thanks for the update!
  16. Sjm9911
    10,789
    8,166
    Hey matt!
