Upgrade Plastic Manual Hand Pump? Replacing the broken original.
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by equest, Jan 13, 2017.
  1. equest
    equest Member
    53
    Dec 22, 2016
    Tampa FL
    I have a new-to-me Coachmen Clipper Sport 086 (2005).
    The plastic manual hand pump was broken (handle broken off) when I purchased the PUP. Does anyone have a suggestion for a replacement hand pump that is of better quality (maybe metal rather than the chintzy plastic that broke)??
  2. Natureangel
    1,079
    249
    Feb 28, 2016
    Illinois
    I put in an electric pump and changed to a regular faucet. I felt the hand pump was useless.
  3. pej
    pej Member
    342
    Jul 17, 2013
    I did the same thing. City water connection on one tap and tank water through pump to the other. The best upgrade in my trailer.
    Photos at... Http://headpond.ca/Palomino.html the pump is a demand pump, but I put a disable switch in as well.
  4. Dudman5703
    Dudman5703 Jeep Guy
    281
    75
    Apr 17, 2012
    Muskegon, MI
  5. Snow
    10,572
    1,339
    If you search around in the "That ain't Stock" section you'll find lots of members who have done the mod of replacing worn out and broken hand pumps with 12volt electric pumps..
    If you take a look on Camping Worlds website you can even find a couple "kits" for doing this..
  6. jumpoff
    jumpoff I'm in a camping state of mind
    1,553
    190
    Nov 3, 2015
    North East Florida
    That really looks nice...very professional.
  7. BrianRosenthal
    BrianRosenthal Member
    58
    Feb 23, 2011
  8. 4xMeteor
    4xMeteor Active Member
    621
    74
    Jul 30, 2012
    Georgia
    I've done several mod's on our pup - check them out here
    - Electric Pump
    - Sink faucet
    - Sink drain
  9. BigRedTruck
    BigRedTruck Member
    427
    Jan 23, 2011
  10. equest
    equest Member
    53
    Dec 22, 2016
    Tampa FL
    I'll probably choose the same replacement.
    I also need to replace the water supply line from the tank which is mildewy/moldy. [XX(]
    The foot pump idea is a good one. I've spent time on sailboats and that is what many use. I like the hands free operation and it seems to provide more "torque"/pressure to pull the water from the tank.
  11. Hoser
    Hoser New Member
    26
    Mar 11, 2015
    I didn't go electric when mine broke, just replaced it with this metal unit and it works great... Just had to make the hole in the counter a bit bigger.
    https://www.amazon.ca/gp/aw/d/B000BGJX88/ref=ya_aw_od_pi?ie=UTF8&psc=1
    Sent from my XT1045 using Tapatalk
