Firehawk068
- Mar 22, 2016
- 288
This Camper came factory with the mechanical-style, pilot-light type Water-Heater.
We use it for hot water all the time.
Since owning it, it has always had an issue with the pilot-light going out at random times throughout a camping-trip.
I'm not sure if it's because we always seem to be camping at higher altitudes? Or what the issue might be?
Over the years of using it I've tried every possible thing I could think of to try and remedy this..................
Cleaning the gas valve,line,orifice,burner,etc.........Replacing the thermocouple. Adjusting the pilot screw more. Adjusting the pilot screw less. Moving the pilot flame closer to the burner flame. Moving it farther away.............I've tried it all!
Anyway, last year while flushing it out before getting it ready for the camping season I noticed little bits of bluish-white material coming out with the usual scale and sediment.
It appeared to be bits of the porcelain lining from the inside of the tank.
Since it is now 15 years old, I figured it's probably time to replace it.
I chose the model that has 12-volt direct-spark ignition, and also has a 110-volt heating element built-in.
Since we do about 50% camping with hookups and 50% boondocking, I figured it would be helpful to have both propane and 110-volt water-heater function.
Same size as the old one (6 gallon) so it should be a direct replacement.
I purchased the Switch-Panel and the 12-volt/110-volt Relay separately.
Removal of the old one was super easy.
Disconnect the two water lines inside, the propane-line on the outside, unscrew the flange from the Camper-wall and it slid right out!
