USB charger and volt meter
Discussion in 'Campsite Electronics' started by generok, May 5, 2019.
  1. generok
    3,353
    2,149
    Feb 7, 2013
    Anchorage, AK
    I got this little dual USB charger and volt meter from Amazon and installed it on the nightstand next to the bed. The voltage agreed with my multimeter so I guess it is accurate. Now we can charge phones even on the battery all night.
    The only problem is that it is REALLY BRIGHT! As soon as we turned off the lights last night it lit up the room blue. I'll have to find some panel tape or something. But I do like a built in USB charger that doesn't depend on shore power.
  2. Kampus
    Kampus Active Member Gold Supporting Member
    208
    206
    Jun 16, 2017
    Slate Belt, Pa
    I have a similar issue with mine as well. The voltage read out isn't too bad. I have a power switch wired in to shut it off when not in use....that however could land a plane. I will be replacing it with a non lighted switch.
  3. theseus
    theseus Living the Darkside...
    3,398
    843
    Feb 6, 2007
    Centerville, OH
    Put a piece of black electrical tape over it at night. That will block the light. That’s a temporary fix though. For a permanent fix I would add momentary on/off switch. Then you can press the button and see the voltage but it is off when you aren’t need it it. This will save your battery when boondocking.
  4. roybraddy
    roybraddy Well-Known Member
    2,394
    960
    Mar 23, 2016
    King George, Virginia
    I ran into same problem here in my Radio/Computer room. I added a nice riser section on my desktop to use a couple of those PHILLIPS 24-inch Smart HDTV sets as computer monitors. I added a couple of those BLACKWEB 6-PORT USB WALL CHARGERS (WALMART) inside the bottom area of the 5-inch riser tops. They all have little BLUE LIGHTS inside the USB ports showing it is on. They light up the room here when I turn out the lights big time as well haha... Makes for a great nite light I reckon...
    This plugs into 120VAC - Most useful to have around... seems like everything now days are using the USB port connector.
    Google image
    Roy Ken
  5. Sjm9911
    10,749
    8,134
    Like we did as kids with the check engine light , lol.
  6. theseus
    3,398
    843
    Feb 6, 2007
    Centerville, OH
    Exactly. Though I did it to an anti lock brake light on a 91 explorer...
  7. Kampus
    208
    206
    Jun 16, 2017
    Slate Belt, Pa
    TPS light....currently [::)]
  8. brwarrior
    brwarrior Active Member
    179
    83
    Mar 26, 2017
    Clovis, CA
    Choose red over blue every day of the week and twice on Sunday.
    As a kid, my aunts VCR. She was the only person that no matter where she lived she had power outages constantly. That little green LED clock light on a VCR is VERY bright in a pitch black room, especially when it's flashing. I would usually shove the remote under the cover over the VCR at some point.
