Using BAL Leveler for extended periods
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by campfam4, Sep 16, 2016.
  1. campfam4
    campfam4 New Member
    Sep 14, 2016
    My pop up is stored on a somewhat un-level grassy/dirt surface. Until I have time to gravel/level the area, is it a bad idea to level with the BAL for extended periods? Its about a 2" - 3" difference from side to side. I have plywood underneath each tire for now as well.
    Thanks so much for your insight!!
  2. Customer
    Customer Well-Known Member
    2,435
    244
    Jun 5, 2014
    If it is being stored, it doesn't need leveled.
  3. Hawkester
    Hawkester Hawkesnest
    1,337
    27
    May 23, 2008
    SE Wisconsin
    Not sure how long long term is but I would think that weather wouldn't be a friend to the Bal if it were months..
    Also plywood isn't the best surface either since it to will hold moisture.
    Anyway to get some 12 x 12 concrete pads or pavers?
  4. friartuck
    friartuck Well-Known Member
    2,902
    122
    Nov 1, 2007
    Perry, MI
    I'll leave my BAL on for a couple of weeks at a time, so I can work on the pup as time permits. It does require extra maintenance (greasing the screw) and I make sure everything is clean and dry before I store it.
    But you don't need to have the camper level to store it. In fact you want a bit of an angle to allow 'weather' to drain off.
  5. Fleetwood Max
    Fleetwood Max Member
    665
    Aug 14, 2005
    St Louis. Mo
    You don't need your BAL in storage as the Customer has said..you want somewhat of an angle, aka front to back or/and side to side, to help with water, snow, run off...
  6. campfam4
    campfam4 New Member
    Sep 14, 2016
    Thanks so much for everyone's insight! My reason for leveling is out of concern for the refrigerators. Pup has 2 refers (3-way inside & plug in which is accessed from exterior).
    I'd rather take it off the BAL to be honest. Still no need to balance?
    Thanks again!
    2016 Rockwood 2716G
    Sent from my SM-G900P using Tapatalk
  7. terry1419
    terry1419 Active Member
    669
    81
    Mar 6, 2016
    Streator, IL
    Should be no concern for the refer to be level unless it is operating. Just don't lay the pup on its side or turn it upside down. [}:)]
  8. Customer
    2,435
    244
    Jun 5, 2014
    If in storage I would assume the refrigerator is not operating so it doesn't need to be level.
  9. campfam4
    campfam4 New Member
    Sep 14, 2016
    Thanks everyone!
    While I'm at it, is it okay to leave a cannister of DampRid inside the door when storing the pup over winter or other long periods?
  10. jeeper88
    jeeper88 Let's go Camping and Jeepin
    883
    63
    Apr 24, 2011
    Ocala,FL
    I have damprid in mine all the time, it helps keep the dampness down. I go thru two tubs a year..
  11. campfam4
    campfam4 New Member
    Sep 14, 2016
    Thank you!
  12. CeridianMN
    CeridianMN New Member
    Sep 28, 2016
    I've got the BAL attached as theft deterrent. There's a chain running through the frame, the BAL, and the wheel. Do I need to take the BAL out of the equation? It's in an outdoor lot in the Denver area for the winter. I plan on monthly check-ins with it.
  13. ByramTra
    ByramTra Member
    49
    Sep 30, 2016
    The main issue I would see would be rust. Sitting on the ground, especially if it is covered in snow, its going to probably start rusting.
  14. tfischer
    tfischer Well-Known Member
    3,683
    1,160
    May 21, 2014
    I'd eliminate it. Doesn't seem to be adding a lot to the equation and they are expensive.
