Using scissors jacks instead of stabilizer jacks
Discussion in 'Stabilizing Your Camper' started by JayGoCamper, Jul 12, 2019.
  1. JayGoCamper
    JayGoCamper Member
    31
    26
    Jun 18, 2019
    I have spent this week working my way through the hookup and set up of my NTU PUP. There are two aspects of set up that I can manage, but could also make a good bit easier. One is the crank process, but I understand that a 12v. cordless drill and a socket wrench will facilitate that.
    The other is dropping the stabilizer jacks, which requires getting on my knees and reaching under the camper. Could I use two pair of these instead and leave them in the TV until I need them?
  2. WrkrBee
    WrkrBee Well-Known Member
    2,587
    994
    Anyway to move the existing stabilizers out from under the camper a little further?
  3. Toedtoes
    Toedtoes Well-Known Member
    1,700
    1,355
    May 28, 2018
    I had similar with my TT and hated them. I ended up using a couple bottle jacks for stabilizing. Quicker and easier to raise and lower.
    JayGoCamper likes this.
  4. BikeNFish
    BikeNFish Well-Known Member
    2,970
    1,882
    Apr 24, 2017
    Maplewood, MN
    As long as you aren't using them to level the pup, you should be fine.
    Blackripley and nineoaks2004 like this.
  5. Blackripley
    Blackripley Active Member
    109
    72
    Jul 21, 2018
    Goleta Ca
    Just make sure you have good points to place the jacks. Big frame members, no wood or small frame cross bars.
  6. JayGoCamper
    JayGoCamper Member
    31
    26
    Jun 18, 2019
    I suppose it could be done, WrkrBee, with the right tools, and some elbow grease, but I'm looking for an easy fix.
  7. JayGoCamper
    JayGoCamper Member
    31
    26
    Jun 18, 2019
    Thanks, Toedtoes. Off to the auto supply store I go!
  8. JayGoCamper
    JayGoCamper Member
    31
    26
    Jun 18, 2019
    Thanks Bike! LMAO at your sig line!
    BikeNFish likes this.
  9. JayGoCamper
    JayGoCamper Member
    31
    26
    Jun 18, 2019
    Gotcha. look for the big iron stuff, not the small. Will do.
    Blackripley likes this.
  10. Toedtoes
    1,700
    1,355
    May 28, 2018
    It's good to have them around anyway. I got a couple 20-ton which moved into my clipper when I got rid of the TT. When I backed the clipper over a boulder and needed to raise it to get back over the boulder without gutting the fuel and black tanks, those two jacks came in REAL handy!
    When I got the FnR, I bought two more and keep them in the Durango.
