Video of how Coleman Fleedwood popups are manufactured
Discussion in 'PopUpPortal TV' started by steppinthrax, Oct 27, 2013.
  1. steppinthrax
    steppinthrax Member
    181
    Aug 7, 2013
  2. smit1088
    smit1088 Well-Known Member
    1,582
    82
    Mar 15, 2011
    Stillwater, MN
    Fun to see this video again . Great way to see the camper bones.
    However, you say we know how they f up the roof... That is the abs roof you are talking about not the one in the bid.
  3. steppinthrax
    steppinthrax Member
    181
    Aug 7, 2013
    I heard that most of their roofs had problems??? Only the older style (Aluminum) ones were good.
  4. steppinthrax
    steppinthrax Member
    181
    Aug 7, 2013
    I also notice how they used 3M quick connects to make electrical connections. I don't particularly care for this. I saw this in my camper and thought the previous owner did a wire job....
  5. woobie
    woobie My PUP is newer than my Tow Vehicle
    163
    Sep 30, 2013
    Adding to this list...Did you notice the PUP was leveled and Stabilizers down when the top was raised. LOL!
  6. EV2
    EV2 Member
    462
    Mar 18, 2008
    Actually the video is not clear enough to tell if the stabilizers are down fully with a load or pressure. It is actually a very good practice to lower the stabs to just touch the ground with no weight or pressure when unhooking and leveling. The practice totally eliminates the possibility of a wheelie if someone enters as the top goes up. With no weight or pressure, there is no effect on raising. Then, later, when convenient, you can load the stabs with whatever weight is needed to properly stabilize the pup to eliminate shake or movement, but if forgotten, no harm.
