Video Review of cheap battery monitors
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by mpking, Jul 24, 2020.
  1. mpking
    mpking Well-Known Member
    1,436
    402
    Jun 17, 2014
    Raynham, MA
    Doing some research for something else, tripped across this:
    He reviews the bayite that's $19, plus 3 others.
    Good info!
  2. zak99b5
    zak99b5 Active Member
    217
    140
    Feb 21, 2019
    I have that monitor with the shunt. I think I watched that video before I bought it. I installed mine with a switch so it isn't always on, so I don't get accurate watt-hours. I just go by the voltage reading--I like that it has two digits after the decimal point, so it's more accurate. Next trip is going to be only two nights, so I will leave it on the whole time and see watt it tells me.
  3. kgesiako
    kgesiako Active Member
    126
    97
    Mar 26, 2016
    Chicagoland area
    8AA22060-A7C9-499A-B819-07139022181E.jpeg 0B07D34F-72FB-48BE-B37B-DFCDDBDB081F.jpeg I also just got done installing the bayite from the same review. I found another guy install it using cat5 cable so you can put ends on battery side and unit side, easy to hook up and do testing during install without constantly have to hook up wiring. So far so good
  4. zak99b5
    217
    140
    Feb 21, 2019
    Does the backlight go out on its own? If so, how do you make it light up again?
  5. kgesiako
    126
    97
    Mar 26, 2016
    Chicagoland area
    There’s a little button you use a pen or something with a fine tip to touch to turn light on and off. You use that same button for setting high and low voltage alarms also.
  6. kgesiako
    126
    97
    Mar 26, 2016
    Chicagoland area
    42658C29-711F-41E0-A54B-554D07028889.jpeg DAA9EEBC-B74E-4610-8A90-D9C7B5068C6D.jpeg Button on right and a pic of my install
  7. zak99b5
    217
    140
    Feb 21, 2019
    I was assuming it was the watt hours reset button. Thanks.
    kgesiako likes this.
