VIKING / IDT LIFT System
Discussion in 'Lift Systems' started by wely, Sep 2, 2014.
  1. Jayp1017
    Jayp1017 New Member
    Jul 25, 2020
    Arnel Puntilar
    Anyway you can text me have some questions about the system you might be able to help since its fresh in ur mind! 2696554850
  2. samgamb
    samgamb New Member
    Sep 7, 2020
    Hello
    I have a 2005 viking 1070st
    No a hole in anything just like new no mildew or mold
    But when you crank it up it does not lock
    From what have found it an idt system
    Know trying to find out if there is a way to fix and what you would recommend
    Like I mentioned it's like new
    Thank you for your help
    Sam
  3. DanDiego
    DanDiego New Member
    Jul 23, 2018
    we had a place connected with Canvas Replacements (in Wisconsin, as I recall) rebuild the system. I removed it and sent it to them (after arranging for everything) and then about 2 weeks later they sent it back. And, I re installed it.
    What they sent back to me was a single box withe the springs folded and all of the other moving parts inside the central 'casing'. I told him that I wanted him to renew anything that looked suspicious. We have been out 3 times since - no problems. Total cost was about $350 including freight to me. Freight from So Cal was about $125. They did good work.
    Doggosfordays likes this.
  4. samgamb
    samgamb New Member
    Sep 7, 2020
    This is so crazy that this is the only way to fix it
    Very surprised that this wasn't a recall to make it right
    I appreciate your fix
    Do you still have the info so I can call them
    What would a dealer do?
    Thanks
  5. DanDiego
    DanDiego New Member
    Jul 23, 2018
    I don't. think this is the ONLY. way. to fix. it - you can get the parts and do it yourself. The weekend it broke, I thought I could get some place locally to fix it - silly me. It's not that complicated, they just don't do it.
    My understanding is that IDT went belly up around 2006 because of repair claims. I have been told that the design is superior to. the goshen system - but evidently IDT didn't have the financial wherewithal to withstand the surge of claims and. to get it right. you. might try. [email protected]
  6. samgamb
    samgamb New Member
    Sep 7, 2020
    Hello everyone
    If any one has a diagram of how the idt direct drive lift system is set up so I know how to take it apart and put it back together or a video
    Please send it to me at
    [email protected]
    It's a 2005 coachman classic 1070st
    Popup
    Thank you
  7. Gspring624
    Gspring624 New Member
    Sep 9, 2017
    I would also like any diagrams. Thanks in advance
    [email protected]
  8. WestVaViking
    WestVaViking New Member
    21
    Jul 18, 2018
    123
  9. Henriëtte Meyer
    Henriëtte Meyer New Member
    Apr 3, 2021
    Hi everyone,
    If anyone has a diagram of how the IDT system works and parts or schematics, please send me an email [email protected]
    We'd appreciate your help!
  10. Tim Hebert
    Tim Hebert New Member
    Apr 29, 2020
  11. osolito
    osolito New Member
    Apr 30, 2021
    Hi Firecapitan can you please forward the information of the cables to my email please @ [email protected]. thanks a lot
  12. Freddie
    Freddie New Member
    May 30, 2021
    I know it has been some time since you posted this but if you still have those files for the additional information on the IDT lift system can you please email that to me also. [email protected].
    Thank you.
  13. Freddie
    Freddie New Member
    May 30, 2021
  14. Freddie
    Freddie New Member
    May 30, 2021
    My V shape metal retainer slipped down too did you ever find a solution to get them back inside? Do you still have the IDT lyft system or did you switch it out for the Goshen system? I bought a second hand camper with the entire lyft system removed and I'm looking to find something that can be a replacement. Any help or suggestions would be greatly appreciated.
  15. Freddie
    Freddie New Member
    May 30, 2021
    Can this idt be replaced with the Goshen? I have no choice the previous owner completely removed the idt system from under the camper. The only things remaining are the lift arms and the useless rear waist high crank. I know I will have to install a winch to utilize the Goshen but I have no other alternative as getting a complete system of parts for the idt is impossible. Any advice would be a blessing.
  16. CTloRIDER
    CTloRIDER New Member
    Jul 22, 2020
    Please email that information
    [email protected]
  17. CTloRIDER
    Jul 22, 2020
    I have a 2006 vicking epic 1906
  18. DPeter
    DPeter New Member
    Sep 23, 2021
    Good evening
    I have a Clipper 2005 with IDT lift system model 10; I wanted to take the main cylinder out and the last spring is stuck inside the telescopic pole and I cannot finish the operation, do you have any solution to help me take the spring our from the pole?
    I also think I did a mistake, I turned the small shaft (of the main cylinder) while springs were loosen and it seems the main cylinder pushed the springs 4-6 inches out; how can I back-up the springs when I cannot connect the guiding tubes to the frame?
    Thank you
  19. KyleD
    KyleD New Member
    Oct 12, 2021
    Good afternoon,
    I have a 2005 Viking saga 2107 with an IDT lift that isn’t working. (Recently purchased it not working). I’ve already removed the whole lift system and replaced both acme nuts because one of them was broke. I got everything put back together and mounted back up to the trailer. I’ve tried to lift the top with it back together now but I still get nothing from it. While it was out of the trailer I spun the drive and the spring would come out as if it would work but now that it’s back under the trailer and I crank it I get nothing. The drive is spinning so id think it was working. Has anybody had this issue?
  20. KyleD
    KyleD New Member
    Oct 12, 2021
    Do you still happen to have any diagrams or drawings of the IDT system? If you do could you please send them to my email, it would be greatly appreciated. [email protected]
