vintage heater!
Discussion in 'Cold Weather Camping' started by Katskamper, Nov 9, 2018.
Tags:
  1. BillyMc
    BillyMc Well-Known Member
    2,003
    1,343
    Mar 25, 2018
    If you use propane with a natural gas orifice it's going to burn hotter than designed for, put out too much emissions, or both.
  2. Katskamper
    Katskamper Well-Known Member
    832
    259
    Nov 21, 2015
    Fort Worth, TX
    well!
    good ol Lloyd to my rescue again! he has all the tools.
    he got the pieces apart, we both looked at the orifice. it had tiny hole, was black, so we think that IS the propane fitting. after we hit depot, & a propane grill place with no luck, united RV looked it up & ordered one for me.
    im using a regular prpane hose with regulator on end that attaches to tank.
    i took the whole heater apart, cleaned off 75 years of dust & rust, including a mouse nest.
    i used paint stripper to get that ugly orange off & repainted it coleman red with silver accents
    while banging it around, i knocked out a cup of grit rust from inside the burn chamber. wow.
    after i reassembled it, it has a better flame, with air valve wide open.
    sure looks better!
    it will help keep me warm !
  3. joet
    5,011
    1,077
    Any place that supplies propane for home heating will have a large assortment of
    orifices
    BillyMc likes this.
  4. Sjm9911
    8,805
    6,207
    Pictures of the newly painted unit!!!!!
  5. Douglas Hooper
    Douglas Hooper New Member
    Mar 30, 2021
    Hi All,
    I was looking for an antique space heater site and stumbled across you. I am restoring an old Welsbach space heater and needed some information. Below is a picture I took of the gas train on my heater. The heater is probably set up for natural gas and I want to use it with propane. I assume I can use 11" WC like the heater in this thread. I don't know what most of the items on the gas train are, please help me identify them. Also, I do not know where the orifice is located I do plan on repacing it with one for propane. Also, this unit will be used outside so I am not too worried about CO or burning my house down.
    Thanks for your help,
    Doug
    A - Shutoff/Control Valve
    B - ? When pulled the rod it is attached to moves through D.
    C - ? Seems to be an elbow but has an adjustment screw on top.
    D - ? Screen tube, I assume other components inside.
    E - I think just fittings adapt to the gas line.
    F - Burner manifold.
  6. Sjm9911
    8,805
    6,207
    Not knowing anything about this type of heater. C looks like an stove type intake , so it controlls the gas intake. Like a old stove oriface.
    B , is strange, but its ajustable, maybe an air intake / flow thing.
    That leads to d, i think this is for the air intake flow, so to distribute the air that b controlls.
    I could be totally wrong. Fire it up with natural gas , check for leaks light it and see, then change it out for propane.
