Voltage drop
Discussion in 'Wiring' started by volts600, Aug 20, 2011.
  1. volts600
    volts600 New Member
    62
    Jul 7, 2011
    So I brought home our NTU pup and cleaned and set her up. It has a new battery Marine/rv battery (not true deep cell but they put it in for free). So when the pump runs the lights dim about 50%. I am an electrician so I will bring my meters and some tools home Monday, but is this normal with other peoples trailers? Just seems like alot of drop to me and that is with it plugged in. It as about the same with it unplugged. Trailer is a Coleman Casa Grande.
  2. Erwin
    Erwin New Member
    524
    Mar 21, 2008
    Rochester, NY
    I would start by checking/cleaning ALL the grounds.
  3. mv520
    mv520 Active Member
    592
    27
    May 2, 2010
    No, not normal. Some dimming yes, but not "50%"
    In tracing the wires/connections, note the power for your ceiling lights *probably* comes up to the ceiling from a pair of wires that are actually on the outside of the PUP just to the rear of the left rear corner by the lift post, with a connector exposed.
  4. volts600
    volts600 New Member
    62
    Jul 7, 2011
    Well I brought my better half out to look at the condition that is happening and after much fooling around (with the trailer) we now agree that the dimming is about 20%. Still seems like alot to me so tomorrow I will be checking the grounds (only common connection). I might upsize the wiring from the battery to the convertor from #10 to #8.
  5. marcham
    marcham New Member
    476
    Aug 2, 2011
    Switch to LEDs, any good quality LED won't dim at all if the voltage sags a little. What gauge is the wire from the battery to the fuse box?
  6. Dammitjim
    Dammitjim New Member
    485
    Jul 20, 2011
    I'm glad you clarified that [LOL]
    There could also be loose connections. I recently had problems with my A/C and the power outlet to which the A/C was connected to was only registering 85V. I took the outlet box apart and sure enough, the cables were all loose.
    Good luck in this new adventure and congratulations on the new addition [PU] to the family!
  7. volts600
    volts600 New Member
    62
    Jul 7, 2011
    The wire from the battery to the fuse box/converter is only a #10AWG. A little small in my opinion. Going to upsize it after I check all the grounds.
  8. marcham
    marcham New Member
    476
    Aug 2, 2011
    That's what I have as well. My incandescent lights would dim a little bit when the pump was running, but 10AWG is fine for a 20-25' run considering the 6-8Amp the pump draws.
    That being said, I'm going to increase the wire size on mine because the voltage drop seems to affect the converter's mode selection, it never seems to go to float, unless the battery is close and hooked up by thick booster cables.
  9. kpthook
    kpthook New Member
    29
    Mar 14, 2010
    I agree on going to a #8. Also if you have the lights on and depending on the fixture style it not just 6-8 amps of the pump. If the fixtures are like mine then it's 18 w bulbs (921's) x 4 or 6 amps for lighting. So now your at 12-15 amps plus whatever else might be on.
    I just upgraded my converter and to make a long story short going to a #8 between the battery and converter made a big difference on reducing the voltage drop.
