Want to be able to use our 4 bike rack
Discussion in 'Cargo Carriers / Bike Racks / Other Storage Option' started by MoiraW, Jun 3, 2019.
  1. MoiraW
    MoiraW New Member
    Jul 28, 2018
    Hi, I have a 1997 Coleman/Fleetwood Pop Up Cheyenne and Yakima 4 Bike Swing Daddy Bike Rack. I need to know what I need to use both together--is there some way to have it go between the vehicle and trailer or better to attach it somehow to the bumper of the trailer? If so what needs to happen? TIA.
  2. Sjm9911
    7,388
    4,775
    The bumper on the trailer would probably not work well. It will un ballance your pup.
  3. Eric Webber
    Eric Webber Active Member
    311
    199
    Jul 7, 2018
    Montreal, Quebec, Canada
    Any hitch receiver splitter is going to mess with your tongue weight capacity because it changes the distance from the hitch to the coupler. Rule of thumb is that your max capacity is now halved - the actual math is close to that and really complicated with a lot of variables.
    Putting a hitch on the tail requires beefing up the bumper, making sure you are still tongue heavy to offset the fulcrum swinging the other way, and also probably requires adding in anti sway of some type
    Roof rack bars are a solid option- either on the camper or the tow vehicle
    If you want to add it to the tongue area without messing with max capacities, this also is a decent option
    https://www.strombergcarlson.com/product/bike-bunk-model-cc-275/
  4. Eric Webber
    311
    199
    Jul 7, 2018
    Depends on how light the tongue is. Mine runs heavy with two batteries and two propane tanks. Plus a cargo tray. More than enough to offset a couple of bikes and the rack.
  5. theseus
    theseus Centerville, OH
    2,896
    441
    Feb 6, 2007
    Centerville, OH
  6. The_Al_Mighty
    The_Al_Mighty New Member
    29
    Oct 24, 2014
    If you really need to use the Yakima rack, have a receiver installed on the front of your vehicle.
    theseus likes this.
  7. Sjm9911
    7,388
    4,775
    I thought 4 bikes would be a little rough. Even with added weight on the toung!
  8. Sjm9911
    7,388
    4,775
    I dont want this to happen!
    MoiraW and Eric Webber like this.
  9. Eric Webber
    311
    199
    Jul 7, 2018
  10. MoiraW
    MoiraW New Member
    Jul 28, 2018
    Thanks for all this info. Safety is number one, then ease and cost. Would attaching a trailer hitch bar to the mainframe of the trailer help or should we just get a roof rack— concerned about attaching anything to the roof and causing other problems.
  11. MoiraW
    MoiraW New Member
    Jul 28, 2018
  12. The_Al_Mighty
    29
    Oct 24, 2014
  13. theseus
    2,896
    441
    Feb 6, 2007
    Centerville, OH
    Just out of curiosity what do you do with the front tires?
  14. MoiraW
    MoiraW New Member
    Jul 28, 2018
    I think that may be the easiest option. Curious about the tires, plus did you order direct? Can’t find prices or order info on the site at first look.
  15. billbillbillbill
    billbillbillbill Active Member
    116
    43
    Sep 4, 2012
    SLC, UT
    I made my own using some aluminum angles and tubes. A local portal member had bought too much aluminum and sold me his excess which was just enough for my build.
    [​IMG] [​IMG][​IMG]
    As for tires, I have a couple of webbing straps that I secure the front tire to the bike frame so it hangs on the bike (can't find a picture with the tires attached).
  16. MoiraW
    MoiraW New Member
    Jul 28, 2018
    Thanks for the suggestion. After talking to both etrailer and a local modular rack dealership this looks like the solution. Found a distributor in Canada (where we are) and it should arrive later this week.
  17. The_Al_Mighty
    29
    Oct 24, 2014
    I modified some Yakima fork wheel holders to attach to the bar.
