Water at bottom front bunk channel
Discussion in 'PopOut (Hybrids)' started by smadeen, Oct 14, 2019.
  1. smadeen
    smadeen Member
    109
    Jul 5, 2013
    West Palm Beach, FL 33407
    I have a 2017 Jayco 16XRB hybrid and was getting ready for an upcoming trip and while moving it I noticed water leaking from around the outside of the front bunk area at the bottom. I popped out the bunk and it was dry except the channel underneath the bunk had water in it. What would cause this? The rear bunk end had no evidence of water intrusion and the bottom channel was clean and dry.
  2. RockyRoo
    6,542
    154
    Jun 8, 2012
    Can you post a pic of what this channel looks like? My first guess is a failing seal around the bunk end, but admittedly am not familiar with the newer Jayco products
  3. Dusty road
    Dusty road Active Member
    836
    118
    Feb 28, 2016
    Conneaut, Ohio
    What kind of latches? The roto vice are adjustable.
  4. bikendan
    bikendan Active Member
    524
    37
    Feb 26, 2012
    Don't believe that Jayco hybrids have the Roto-Vise system.
    Dusty road likes this.
  5. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    It's likely to be the "tired" seal. There is an easy fix. Look for high-density rubber foam weatherstrip by Frost King in HomeDepot. Add this on the metal rim all around where the original seal is in contact with the camper.
