Water Filter on Water Heater Discharge
Discussion in 'Plumbing Systems (Blue, Grey, & Black)' started by jdkmrc, Jul 1, 2019.
  1. jdkmrc
    jdkmrc New Member
    Oct 3, 2018
    I recently flushed my hot water tank and a lot of debris came out, including what appears to be tank lining???
    Has anyone installed a water filter strainer on the water heater discharge side to catch any water heater crud?
  2. Sjm9911
    6,571
    3,942
    The crap is from the water heating up. If you put a screen on the discharge im sure it will clog up. Dont drink hot water. Even at home. Dont cook with it eaither. I had hard wayer where i used to live , it takes a toll on the plumbing system.
  3. nineoaks2004
    7,898
    3,497
    Dukes, Fl
    Leave it alone, just empty and flush it out ever so often. I agree with Sjm9911 that the hot water will be unsafe to drink.
  4. BillyMc
    BillyMc Well-Known Member
    1,433
    756
    Mar 25, 2018
    Being that I can't always be certain of the water source I don't drink the water from the PUP (hot or cold). I do however cook and perk coffee with it. I only use the hot water for washing dishes or bathing. The supply has a screen, filter, and another screen. The faucet has an aerator/screen also.
  5. bheff
    bheff Well-Known Member
    1,504
    911
    Feb 24, 2011
    NW Arkansas
    Why do you say it would be unsafe to drink?
  6. Sjm9911
    6,571
    3,942
    All hot water is, it sits in a tank and boiles repeatedly. The minerals sediments and such come out of it and it leaches the lead from the solder and copper from the pipes , and whats left of your aniod rod is in there also. In resturants they always use cold for cooking. Your atually supost to drain your water heaters yearly, who does that? If you do tou will see the sediment build up on the bottem and you will never drink ot again! Drink the cold, after it runs for a few.
  7. bheff
    1,504
    911
    Feb 24, 2011
    NW Arkansas
    I drain mine after every trip, flush out what ever sediment (rarely is there any) and let it dry. Then the system gets sanitized on the way to the next campground if I plan on using the fresh water tank. Otherwise the filter will take care of any particulates from the camp post.
  8. Sjm9911
    6,571
    3,942
    If you say so. But that anoid rod has to go somewhere when it erodes. I rather it not be my stomach!
  9. nineoaks2004
    7,898
    3,497
    Dukes, Fl
    All hot water heaters do not have an anode rod, Atwood does not have one
    xxxapache likes this.
  10. Sjm9911
    6,571
    3,942
    Correct, but then the water absorbs the aluminum from the tank.
