Water heater anode.
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by WVhillbilly, Oct 19, 2019.
  1. WVhillbilly
    WVhillbilly Well-Known Member
    676
    465
    Jun 6, 2018
    WV
    Clean, replace, ignore?
    Looks bad for a 2 year old camper I think.
  2. bheff
    bheff Well-Known Member
    846
    394
    Feb 24, 2011
    NW Arkansas
    Might as well replace it.
    Sjm9911 and WVhillbilly like this.
  3. WrkrBee
    WrkrBee Well-Known Member
    2,451
    936
    It's out. Replace it. It's about to fail at the plug.
  4. davido
    davido Active Member
    877
    174
    Jul 17, 2014
    Not really. There's a non-sacrificial shank running down the middle that is totally in tact. This is about how one of those will look after a couple of years. It still has plenty of material left for one more season. It may look like it's about to fall off, but only in the same way that a corndog looks like it's going to fall off the stick, because the stick is such a narrow diameter relative to the meat/breadding.
    theseus likes this.
  5. WVhillbilly
    676
    465
    Jun 6, 2018
    WV
    These seem to be pretty universal, and I can get 2 on Amazon for $15.
    So I'll just replace it next Spring.
    I thought that would be the thing to do, but advice about something I don't know much about is always appreciated.
  6. Snow
    10,108
    1,028
    Always use to replace ours each and every spring.. figure since I had it loose from winterizing and out again for flushing the tank.. may as well start new..
  7. WVhillbilly
    676
    465
    Jun 6, 2018
    WV
    I would have thought that these would last more than a couple years.
    But I'm not sure the old truck camper I had even had an anode in the heater.
    I knew a lot less about this stuff then.
  8. xxxapache
    2,870
    864
    Not all of them have an anode. Atwood with an aluminum tank do not.
  9. joet
    4,683
    920
    Dometics do not have anode rods either, aluminum tank, Suburban's use a steel tank. There are 2 types of anode rods, One had a raised place on the end and the other is smooth. Two different materials. If I remember correctly you are supposed to alternate between the rods.
  10. Dan Wilson
    Dan Wilson Active Member
    157
    122
    Jan 30, 2019
    Appleton, WI
    It is entirely dependent on how many hours of service, not so much years. Having said that they are pretty cheap and easy to replace.
  11. theseus
    theseus Centerville, OH
    2,861
    410
    Feb 6, 2007
    Centerville, OH
    Suburbans have a porcelain lined steel tank. I have seen after market anodes for the Atwood units. When I install water heaters (or replace) I use the same brand as was in the unit or the one based on the size of the hole that means less work.
    That rod looks fine for at least another year. Mine get changed about every 3 yrs or so, depending on how much use I've given it.
  12. neighbormike
    2,274
    1,661
    Oct 6, 2012
    WI
    I think mine looked worse than that after one season! They are cheap enough so I figure I will install a new one each spring.
