Water leak
Discussion in 'First Time & New Camper Owners' started by Franchesca, Apr 12, 2021.
  1. Franchesca
    Franchesca Active Member
    106
    43
    Nov 2, 2020
    Massachusetts
    Connected my 2005 flagstaff max 228D to town water today. Then water started coming in the camper near the heater or under the pullout dinnette area. I went under the camper and nothing was wet. I had already disconnect the water. The water hose looked fine I saw no cracks. The water heater is no where near where the water was coming in. upload_2021-4-12_15-9-56.jpeg upload_2021-4-12_15-8-24.jpeg upload_2021-4-12_15-9-13.jpeg
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    Yep, looks like the outside is dry. So give us some pictures of where it was leaking inside.
  3. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
  4. Kyle R Thorson
    Kyle R Thorson Active Member
    143
    123
    Aug 29, 2019
    Arizona
    If connecting to the city water inlet on your camper make sure you are using a pressure regulator. As opposed to filling your storage tank and using 12v pump there is no need to use a pressure regulator.
  5. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    I do have a pressure regulator attached. I never filled the storage tank to use with the water pump. That’s the next thing I will try. Along with the water heater.
    Kyle R Thorson likes this.
  6. generok
    3,358
    2,150
    Feb 7, 2013
    Anchorage, AK
    Is the anode rod in the water heater and tight?
  7. Raycfe
    17,808
    3,288
    Looks to me like it is coming from the cabinet under the sink. I would start the search there.
    By the way....... nice clear photos. How about one inside the cabinet.
    Franchesca likes this.
  8. theseus
    theseus Living the Darkside...
    3,401
    843
    Feb 6, 2007
    Centerville, OH
    I’m going to out on a limb and predict it is your water pump. Loose fitting or such. I had this happen to me in my Bayside, water coming out from under the slide where the pump was hidden. I just needed to tighten a few fittings.
    jmkay1, Terry Poole and Sjm9911 like this.
  9. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    I don’t know anything about an anode rod. Where is it?
  10. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    When I opened the cabinet that holds the water pump there was water beneath but the pump was dry. I think it might be a loose connection. Will recheck tomorrow.
  11. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    What does the anode rod look like and where is it exactly?
  12. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    Its coming from where the water pump is. Might be loose connection on one of the hoses.
  13. LilRed
    LilRed Well-Known Member
    732
    359
    Jan 9, 2021
    Long Island NY
  14. Raycfe
    17,808
    3,288
    That trim with the screws in it may help to remove the lower panel for a good look see.
  15. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    You were correct. water coming from beneath the water pump today. I ordered a new one. I will attempt to disconnect where its mounted so I can get a better look.
  16. WrkrBee
    6,569
    3,461
    Pull it and look at it before ordering. Could be a loose fitting or hose.
    Kyle R Thorson and theseus like this.
  17. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    Nothing was loose and the screw beneath where was leaking is totally rusted. Must of been leaking for awhile.
    LilRed likes this.
  18. Spot09
    Spot09 Member
    38
    Jun 12, 2021
    Oshawa, Ontario, Canada
    I am having a similar problem. I hooked up the water to my house and the shower was leaking. I replaced the seats and springs and that solved the problem. After a few hours there was water dripping down and I thought maybe the seats blew but it wasn't the problem. I opened the kick plate and notice the pump leaking (picture attached). Why is water routing through the pump when I am not using the holding tank?
  19. Sjm9911
    10,775
    8,150
    Backflow preventer. Check that. Sometimes they get stuck open.
  20. Spot09
    Spot09 Member
    38
    Jun 12, 2021
    There is a small hole in the middle where the water is dripping out. That is the backflow preventer? I'd it is stuck open, how do I close it?
