1. sonoma camper
    sonoma camper New Member
    45
    Jul 21, 2009
    Sonoma County, Ca.
    Hello,
    We have a Coleman/Fleetwood and I had to replace the water heater. I thought while doing it, i would add a water heater bypass. All went good except I need to add a longer water line from the heater to the bypass. The flexable reinforced water line is 3/8 ID and I can't find this size anywhere. I need about 12" to 2 ft. of hose/line. Does anyone know where I can find a water line so that I can finish this project?
    thanks,
    Sonoma Camper
  2. huizarr
    huizarr Member
    432
    Nov 19, 2009
    I know my local Home Depot carries various size hoses, some reinforced and some not. It is not not alway going to be under pressure so do you need the reinforced line?
  3. dackley
    dackley 1999 Jayco Heritage Laurel with popout
    261
    Dec 24, 2010
    Well since we all use a pressure regulator at the city water hook up,(these systems cant withstand city water pressure)so you better have one, homedepot does sell the line and fittings for camper its clear and braded.
  4. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
    I have looked at Home Depot, Lowe's, etc. None have the 3/8" ID that I need. All that I have found is standard ID's such as 1/4", 1/2", 3/4" etc. probably will have to get it on line, but so far no results.
  5. dackley
    261
    Dec 24, 2010
    Try lowes,ace,camper store,tractor supply store, good hunting.
  6. wileetoyote
    wileetoyote http://www.popupportal.com/index.php?topic=13105.0
    221
    Feb 13, 2008
    Chandler, AZ
    McMaster Carr...
    I've used them off and on for years... another source is Grainger but I prefer McMaster.
    http://www.mcmaster.com/
  7. 1madscot
    1madscot Member
    256
    Nov 6, 2010
    Any decent marine supply store will carry both pressurized and unpressurized hose in 3/8". West Marine and Boat US are just about everywhere, though be prepared for the $$$ when you go there.
  8. Twisty
    Twisty New Member
    4,375
    Aug 24, 2008
    Hillsboro, Oregon
    Ace is the place [;)]
  9. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
    Eureka, I have found it! I found a 3/8" ID reinforced hose at West Marine.
    Thanks for all of your suggestions.
