Water pump impeller.
Discussion in 'Miscellaneous Repairs & Maintenance' started by Grandpa Don, Sep 17, 2019.
  1. Grandpa Don
    Grandpa Don Active Member
    465
    227
    Sep 5, 2018
    I found this old water pump in an abandon camper. The motor works, but the impeller is shot. There is no name on the pump. Does anyone know where I could find a new impeller for this? If I can get it to work properly I would like to use it to make a water transfer system from bucket to camper or to make an outdoor shower. It works for a few seconds and put out a lot of water. But then it slowly stops . The motor keeps running, but only a trickle of water starts coming out. It was in a Pickup slide-in camper and is probably 25 years old.
    I know what you're thinking! Just buy a new pump. But I like to fix things up.
  2. SteveP
    SteveP Well-Known Member
    1,604
    459
    with the diameter of the shaft, the diameter of the housing the impeller rides in, and the thickness of the impeller look at outboard motor impellers to find the closest fit.
  3. tombiasi
    5,704
    1,320
    Perhaps the impeller is just slipping on the shaft. Did you open it?
  4. Grandpa Don
    465
    227
    Sep 5, 2018
    I've serviced my outboard motor impeller and it is much bigger than this one. This one measures only 1 1/4 inches across.
  5. tombiasi
    5,704
    1,320
    Sorry I didn't see the picture the first time. Looks like the center of the impeller is worn.
  6. Grandpa Don
    465
    227
    Sep 5, 2018
    The center is fine. It's the fins that are deformed. I'm going to try putting it in hot water to see if I can straighten them out.
  7. tombiasi
    5,704
    1,320
  8. Grandpa Don
    465
    227
    Sep 5, 2018
  9. Aladin Sane
    1,081
    109
    Jul 3, 2008
    Iowa
    You could try flipping the impeller over in the case. You would need to bend the fins the correct way as you fit it back in the case, but they will then be firmly held against the outside of the case.
    Grandpa Don likes this.
