Water pump is sputtering, spitting
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by NoTrumpAce, Nov 4, 2019.
Tags:
  1. NoTrumpAce
    NoTrumpAce New Member
    Apr 26, 2015
    Lisle, IL 60532
    We have a Forest River Premier 2018 2516g popup. The water pump has worked well, pumping a consistent flow to all faucets. I started to winterize this week and the pump started sputtering and spitting as I tried to draw anti-freeze into the system. I had already cleaned the water filter on the back of the pump and had the siphon tube at the bottom of the anti-freeze bucket. I managed to get anti-freeze through to all the faucets. I have not made any changes to the water system since we bought the popup and I have completed this process without problems each fall. Any ideas why the pump is not performing as expected?
  2. Snow
    10,097
    1,024
    Sounds like it is sucking air in from the siphon tube..
  3. tombiasi
    5,311
    952
    At any rate, air in the line from somewhere.
  4. bheff
    bheff Well-Known Member
    829
    383
    Feb 24, 2011
    NW Arkansas
    Yep, what they said
  5. NoTrumpAce
    Apr 26, 2015
    Lisle, IL 60532
    Thank you for your suggestions. I really appreciate the campers that take time to answer.
