Water pump keeps running
Discussion in 'Plumbing Systems (Blue, Grey, & Black)' started by Paula Scott, Oct 12, 2021.
Tags:
  1. Paula Scott
    Paula Scott Step lightly; Leave no trace.
    Oct 20, 2011
    Hi, Polly Pop-up here. I searched high and low for water pump problems but most postings were about anti-freeze. My pump has recently been staying on even after a 10 or so minute run. I have to flip the switch off to get it to stop. Lucky me! This is my first water pump problem lol. It seems as if I had everything else on Daisy (my pop-up) fixed at least twice! All hints and advice, especially easy stuff, welcomed and appreciated. 2015 Forest River Rockwood. [RTM]:smile_question1:[MOD]
  2. myride
    myride Well-Known Member Gold Supporting Member
    1,196
    639
    May 14, 2015
    Edmonton, AB
    You have a leak in the system. Once the pump fills or "loads" it should shut down and a sealed system will keep it that way until the water system is used and the need to refill. It's "sucking" air somewhere and continues to run.
  3. gladecreekwy
    1,505
    2,296
    Sep 25, 2016
    Jackson Wyoming
    Yup. What myride said. It’s losing pressure somewhere
  4. tombiasi
    6,600
    2,172
    Could also be the pressure cutoff switch not working.
    Sjm9911 and myride like this.
  5. myride
    1,196
    639
    May 14, 2015
    Edmonton, AB
    Yup...that too....
  6. Raycfe
    17,686
    3,187
    The pump is not building up pressure ......... You are out of water .......or sucking air into the pump ........or you have a leak.
    Also remember that if the water heater is empty it will take 6 gallons to fill it. I would hook up city water and check for leaks first.
    myride, xxxapache and Sjm9911 like this.
  7. xxxapache
    4,051
    2,322
    Does water come out of the faucet when you open it?
  8. Paula Scott
    Oct 20, 2011
    Hi, Yes it comes out strongly.
  9. Jonnieb
    Jonnieb New Member
    Jun 5, 2017
    Ontario, Canada
    Check your popup valves (usually on the trailer floor inside a cabinet) that are used to drain the piping. If they are not pressed down securely, they will sometimes cause a small pressure leak.
