water pump kicks on every now and then
Discussion in 'Miscellaneous Repairs & Maintenance' started by ham fam, Sep 23, 2019.
  1. ham fam
    ham fam Member
    39
    Jul 20, 2016
    Kaukauna WI
    My 12 volt water pump, keeps kicking on just for a second every now and then. lt is only used to draw water from the holding tank. Anybody ever have a similar issue? And a solution?
  2. BikeNFish
    BikeNFish Well-Known Member
    3,349
    2,259
    Apr 24, 2017
    Maplewood, MN
    Last night, I drained the tank, then turned on the faucet to remove the water in the lines. Once the water was removed from the lines, the pump ran until I turned off the power to the pump. So, I'm guessing that you may either have a small leak or another reason why you are getting air in your water lines.
  3. Sjm9911
    5,959
    3,417
    Theres a diapram between the pump and tank. Sometimes it gets stuck a bit.
  4. Bradley E Dixon
    Bradley E Dixon New Member
    25
    19
    Jul 1, 2019
    Minot, ND
    Mine did the same thing on our first "maiden" voyage camping.
    I found that the "low-point" cold water drain T-VALVE under the sink was not seated correctly and was leaking onto the ground under the camper. Thus the 12v pump would run when the pre-set pressure would drop.
    The tiny C-clip had popped out and was laying on the floor next to it (whew). Seated the valve - Re-inserted the clip - no issues since.
    ( pic is the actual valve - but it stands up with the "T" at the highest point and the barbed end directly opposite goes thru the floor w/ a small hose attached)
    My 2cents...
  5. Snow
    10,566
    1,338
    Yup.. the water pump on our TT does the same.. the pump is sensing a pressure drop to it runs to rebuild the pressure.. 2 of the common things that leak are the check valve on the city water connection (usually leaks if some has cheated while winterizing and left the pump turned on, when they pressed the "pin" to open the check valve.. the seal gets rolled over) or the over pressure valve on the water heater... less common but will cause the same issue are, dripping faucet, one of the swaged fittings on a line is not tight allowing air "in", water heater anode/plug leaking or if your trailer has low point drains, one of them leaking.... In my case it is the drain plug on the water heater drips a little bit..
  6. mpking
    mpking Well-Known Member
    1,322
    331
    Jun 17, 2014
    Raynham, MA
    Ditto on the leaking water heater anode for me. Had to reseat it to stop it.
  7. Econ
    Econ Well-Known Member
    665
    317
    Aug 18, 2019
    Deep South
    And if you boondock it is using battery juice to be in standby.
  8. mpking
    1,322
    331
    Jun 17, 2014
    Raynham, MA
    That is not be true.
    The pressure switch is more like a second on/off switch. When pressure is above the threshold, the switch is off, no current is drawn. When it drops below the threshold, the switch turns on, and the pump draws power.
    xxxapache and alabasterjar like this.
  9. joet
    4,965
    1,057
    Internal check valve in pump leaking? Which is common
  10. kitphantom
    12,071
    1,111
    We only turn the pump on when we plan to be using it, though we do forget to turn it off once in a while. With the original pump in the TT, it would kick on relatively often if left in standby state, we never found a leak. We upgraded to a better pump, which is less noisy, and takes much longer before it gives a quick trill if we forget to turn the pump off.
