Water Pump/Sytem Question
Discussion in 'Miscellaneous Repairs & Maintenance' started by threebeachboys, Sep 14, 2015.
  1. threebeachboys
    threebeachboys Active Member
    429
    60
    Jul 18, 2005
    Hey All - Well, as long as I have been camping in a pop-up (20 years), I've only used the on board water system 1x. And did not use the water heater with it.
    So, do I need to do anything special to use the water heater when using the on board water tank/pump? I know you are not supposed to light the heater unless there is water in it. . . . . How does the water get there? The same way as with a city hook-up? Gosh, I feel like an idiot asking. . . . .
    I have an Aliner Ease with electronic ignition heater. The water pump system worked when I bought the camper in June, so I expect it is still ok. Thinking of venturing out to an electric only site.
    Thanks.
  2. ill.plainsman
    ill.plainsman happy, happy
    953
    Jun 21, 2012
    Champaign Illinois
    you probably just need to make sure there is not a bypass involved. a bypass is where the water gets to the pipes close to the water heater but doesn't doesn't allow it to go in. imagine an capitol "H". the water comes in on the bottom left and the heater is between the upper 2 pipes. the house or camper faucets are to the right bottom side. if a valve in the center is open and the one going up on the left and right are closed then no water can get in the water heater. if the 2 valves are open to the WH then it can fill up even if the one in the center is opened or shut. of coarse you won't pull any hot water unless the center one is closed. to be sure you have water in the WH open a faucet at your sink. cold first. when your sure [steady water delivery] on the cold side open the hot side and close the cold. when it stops sputtering air you have a full WH.
  3. tenttrailer
    3,495
    496
    Jul 18, 2013
    Thornville, OH
    yep water get in the hot water tank the same way, but via the water pump and the water from the tank.
    Just turn on the pump run it and open the hot water faucet to bleed out the air. Once the hot water tank is bleed you can fire up the water heater.
  4. Snow
    10,973
    1,623
    Since the water hasn't been used for awhile, I recommend sterilizing the system prior to using it.. Including sterilizing the HW tank..
  5. Antipodes
    Antipodes Call me Paul
    772
    75
    Jan 28, 2015
    Christchurch, New Zealand
    Ditto the above and recommend pulling the anode out to check or replace it as it has not been used in some time.
    (when you sterilise, you will probably pull this to drain the tank anyway!)
  6. ill.plainsman
    953
    Jun 21, 2012
    Champaign Illinois
    good idea on pulling the heating Anode as I think I read on my replacement last spring , that high levels of chemicals could damage the heating element.. rinse out very well when done. [:D]
