Weather Radio
Discussion in 'Campsite Electronics' started by Econ, Feb 24, 2020.
  1. Econ
    Econ Well-Known Member
    1,486
    914
    Aug 18, 2019
    Deep South
    We do not keep up with the latest tech. Does anyone have suggestions for 1) a portable weather radio 2) a good FM-AM radio that will pick up at range.
    We went camping last week and checked the weather for the campground before leaving. All was good. We were a 100 miles from the "big city". The campsite had an occasional 1 bar of cell phone reception. We did not have a TV with us. The campground was sparsely populated. We have an old AM/FM radio in the camper that came from an Estate Sale.
    On night two the camp host came by at dark thirty. There was a tornado warning, 60 mph Straight line wind Watch, thunderstorm watch, hail watch, etc that night. He gave us a list of very local radio stations.
    The next two hours were spent bandscanning for radio stations. The only few that could be received were to the east and they weren't in the tornado box so they had regular programing. Tornadoes in the deep South come from the SW.
    At home we have a tornado radio that you punch your zip code into. This would be difficult if you were on the road camping. On the motorcycle there is a weather band radio that scans 7 frequencies for a broadcasting NOAA station.
    What I like about the Midland tornado radio is the external antennae jack. Is an Aliner with an aluminum frame nothing but a Faraday Cage?
    So what do I want??? I was wondering someone has done the research on weather radios and has a good suggestion. We don't mind paying for quality.
    At home you have access to the TV. This was our first occasion to have a warning while camping. The lesson learned is to make a list of radio stations 80 miles SW of any campsite we will be staying at.
    Thanks
  2. kcsa75
    5,204
    3,238
    Sep 9, 2013
    Kansas City
    We have a Midland NOAA weather radio in the camper. You can get an up-to-date weather report on demand or set it to alert you of impending storms or other severe weather.
    Midlandusa.com/product/wr-120-weather-radio/
    gladecreekwy likes this.
  3. Anthony Hitchings
    3,054
    1,809
    Mar 2, 2019
    Oakland, California
    it matters less what you get than you test it before needing it, ours has a battery and a crank charger, AM, FM, Weather , light , mini-USB charging input
  4. Raycfe
    17,759
    3,252
    We have an emergency crank radio. Have had it for 15 years ...... other than testing it now and then never used it. Our tow vehicle radios always worked way better than anything else.
  5. roybraddy
    roybraddy Well-Known Member
    2,394
    959
    Mar 23, 2016
    King George, Virginia
    We use the same NOAA WX Receiver as KCSA75. This works great and will respond to selected counties etc...
    In my POPUP trailer I have a NOAA RECEIVER that tunes to an ACTIVE WX CHANNEL when you first power it 'ON'. It is always ON when we are setup at the camp site. Sounds off good and loud alert tones etc... Would not be without a NOAA WX ALERT setup.
    The camp area may or may not have any emergency place to go to. You want to have as much early warning as you can get. Our OTA local TV setup is a hugh help in this regard as well...
    Our TV setup is using the Winegard BATWING antenna up on a antenna setup we put up as soon as we setup for camping. The BATWING is manually turned to pickup local TV reception. It is very rare we will not pick up something...
    Roy's image
    I am also an avid Amateur Radio operator and have a Ham Radio in both our truck as well as in the POPUP trailer.
    WX Information is a high priority for us in our OFF-ROAD Camping...
    Roy Ken
    kcsa75 likes this.
  6. Grandpa Don
    Grandpa Don Well-Known Member
    1,421
    1,072
    Sep 5, 2018
    Southern California
    I picked up this radio at an Estate sale for a whopping $2.00. It was brand new in the box and works fantastic. It is powered by a battery that can be charged by Solar or a hand crank. You can also plug it in to an AC or DC power source.
  7. bheff
    bheff Well-Known Member
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    How about buying a cheap Baofang UV-5R handhelds off of Amazon....crazy long battery life and has a built in dedicated button for weather.
  8. roybraddy
    2,394
    959
    Mar 23, 2016
    Hey Grandpa Don - I assume this is your radio "Kaito KA500 5-way Powered Solar Power,Dynamo Crank, Wind Up Emergency AM/FM/SW/NOAA Weather Alert Radio"
    Google image
    I probably should pick up something like this. The ones I have are physically mounted in my house or off-road POPUP trailer. Need to carry something like this in my truck. I notice it says it has 7 pre-programed WX CHANNELS. Curious how this works for you when you go into different areas. I suspect you may have make program changes for the different areas you go to when on the RV trips...
    I also see these may have the same problem I have with my CC POCKET AM/FM/NOAA radio. You can't listen to FM CHANNEL and select ALERT to come on when the NOAA is activated. My CC radio is suppose to do this but I have never got any of that to work haha
    I like the different ways of powering up the emergency radio. Should work for you in about all of the situations you may get into when in travel mode.
    I see this is available from my favorite store being AMAZON haha... I will pick the YELLOW color though haha...
    Roy Ken
    Grandpa Don likes this.
  9. Econ
    1,486
    914
    Aug 18, 2019
    Deep South
    Our motorcycle scans the 7 NOAA channels for one that is receiving and locks onto it. They set the transmitters apart enough so you can only pick up a couple of frequencies at a time
    Keep the replies coming!
  10. Grandpa Don
    1,421
    1,072
    Sep 5, 2018
    Southern California
    Actually mine is also Yellow. But I could only find a picture of a Red one on the Web. There is a knob to select the different weather channels. I haven't played with this one very much, so I am not really familiar with all that it can do. I just know that for $2.00 it was a Hell of a deal.
  11. kcsa75
    5,204
    3,238
    Sep 9, 2013
    Kansas City
    I noticed this on one of our local TV station weather sites and thought it may be of interest. Probably no good if you don't have cell service, but interesting nonetheless.
    Stormshieldalerts.com
    Named one of the best in the nation, Storm Shield App is available for iPhone and iPad on the Apple App Store, and Android on the Google Play Store.
    Storm Shield App provides storm-based alerts for tornado, hurricane, flood, thunderstorm, winter storms and other life-threatening weather events via voice and push notification.
    "Storm-based alerts help reduce false alarms by alerting you to severe weather based on your exact location within a county," according to Storm Shield's developers. "Conversely, traditional county-based alerts can result in false alarms, warning you when your location in the county is not within the threatened area."
  12. Econ
    1,486
    914
    Aug 18, 2019
    Deep South
    One of the local politicians wanted to discontinue the local tornado sirens and go strictly cell phone based. Do you want to be dependent on a strictly tower based warning system? What are the first things to go in a tornado?
    I called the local weather bureau a couple weeks ago. They had never thought about campers and their needs.
  13. roybraddy
    2,394
    959
    Mar 23, 2016
    Thanks for the info. I have the MIDLAND WR-120 model from WALMART here in my radio room and I put in the settings it needs and next time I look at it the settings are gone. It still picks up the NOAA station but doesn't go into alert mode now... Used to haha...
    I'm ready to change it for something else...
    I think my neighbor has some thing like you radio. Its yellow anyway... He has it on the hood of his car when he is working on something...
    I got an order going to AMAZON today so think I will add this one... Its around $45 or so...
    ADDED UPDATE: Just ordered it - will be here in the morning at 10PM... Have no idea how they do that haha... geesch
    Roy Ken
  14. jbirdt2001@yahoo.com
    [email protected] Active Member
    334
    47
    Aug 9, 2011
    North Dakota
    We have a dedicated NOAA weather radio from Motorcycle camping years ago also 4 walkie talkie with FRS weather channel for grand kids
  15. McFlyfi
    McFlyfi Well-Known Member
    754
    456
    Aug 1, 2014
    Thousand Oaks CA
    I installed a AM/FL/Bluetooth/Weather band "car stereo" in place of the stereo that came with the Niagara. I also pigtailed the existing antenna (it was wound around some pegs behind the mwave) so I can stretch it out through the storage door and gives me 7-10 feet of antenna. Works pretty well.
    I also have a pair of Motorola Talkabouts that have Wx band, but their range isn't that good.
  16. Grandpa Don
    1,421
    1,072
    Sep 5, 2018
    Southern California
    This one has an alert feature, but I have never heard it go off. I don't really turn it on much. As I said, I got this one at an Estate Sale for only $2:00. It is brand new still in the box. I don't think who ever owned it had never even taken it out of the box. It's a pretty darn cool radio.
  17. Econ
    1,486
    914
    Aug 18, 2019
    Deep South
    I have decided I will find a tornado radio locally and buy it. Midlands are sold by everybody locally - this is tornado alley.
    Most radios are made by China and the virus has been so politicized the info about how long it can survived on a hard surface is suspect. If my choice is bad reconsideration will happen this summer.
  18. davido
    davido Well-Known Member
    1,217
    543
    Jul 17, 2014
    Many of the Midland and Motorola 2-way FRS/GPRS radios have weather receivers with SAME built in (automatic alerts). Weather radio broadcasts are pretty reliable to pick up, in my experience; I don't recall the last time I found myself somewhere that reception of at least one of the broadcasts wasn't available. I like the 2-ways for this because of their portability, and because they also help if I need to stay in touch with kids or something. Although nobody really monitors FRS radio bands for emergency purposes, it is possible that if I were to go missing someone might pick me up on a scanner, too. So there's the safety aspect as well.
    They're not super expensive either; $35-$75 will get a pretty good set of radios. If you really want to throw down some money you can get one with a GPS built in, too. That's always seemed a little lavish to me though.
