Storm Trooper
Home is where you park it!
This post is for those of you with Weber Q grills.
I have a Q220 that recently stopped flowing gas.Took it all apart as much as I could,
cleaned and blew out everything possible, not much really.
Put it back together and the gas still wouldn't flow.
I did a google search and came up with quite a few Weber Q grills regulator problems.
It seems that the regulators on the Q grills are failing.
Then I called Weber and they were aware of the problem and told me what to do.
I had already tried everything they told me to do, so they sent out a new regulator free of charge.
They told me 5 to 7 days. It came in within 3 days, but alas, it wasn't packed well and was broken.
I called back and they overnighted the replacement better packed this time.
My Q220 was over a couple of years old and is now working fine with the new regulator.
Just thought that those of you with Webers Q's should know about this problem and that Weber does stand behind them.
