Weight distribution hitch
Discussion in 'On The Road' started by Odie2013, Jun 23, 2017.
  1. Odie2013
    Odie2013 New Member
    Jun 15, 2017
    Can I put a weight distribution hitch on a starcraft 2107, it has a c channel chassi. I am towing with a kia sportage, and its tipped up a little.
  2. Snow
    10,183
    1,089
    Short answer .. NO.
    "C" channel frames cannot support the loads a WDH would place on them.. I would also suspect a Sportage would be similar..
  3. SpaceGuy85
    SpaceGuy85 New Member
    May 1, 2019
    League City Texas
    Actually, not true. They do make the brackets for the C channels, or, you can just have them welded to the PUP frame. The equalizer bars run from the brackets on the trailer to the equalizer hitch. So it does not matter how the car is configured, well, except for a correct Class III or IV hitch. But, not sure about the max payload for the Kia Sportage.
  4. Snow
    10,183
    1,089
    "C" channel tongues and frames will bend and could snap right off.. Friends had it happen to their "C" channel framed pup.. So yes it is true, also if you read many pup manuals for those with open "C" frames, the manuals state that it is not recommended to use a WDH as damage can occur.
  5. NMroamer
    NMroamer Well-Known Member
    549
    290
    Apr 21, 2016
    Albuquerque NM
    A picture would help understand what you are trying to accomplish. Maybe a suspension upgrade on the Kia would be in order.
  6. GreyFox
    GreyFox Well-Known Member
    1,484
    715
    Oct 10, 2018
    S Ontario
    Actually - true. ;) Has nothing to do with being able to mount the WD frame brackets but the fact that the trailer's C channel frame can easily bend from the forces imposed by WD. Obviously the OP can choose to believe what he wants but I sure wouldn't use WD with any C channel frame trailer.
    Snow, neighbormike and durhamcamper like this.
  7. Raycfe
    15,397
    1,573
    Deleted
    neighbormike likes this.
  8. Ladiesman
    Ladiesman Active Member
    236
    119
    Feb 6, 2018
    As someone with a little experience using a WD on my TT there is no way I would use one on a C channel frame.
  9. durhamcamper
    durhamcamper Active Member
    743
    198
    Apr 21, 2010
    Pickering, Ontario
    So you are comfortable about your absolute knowledge that no damage could or will occur to the c channel frame of this poster's pup from the force exerted using weight distribution? Wow. Great advice! Snow and I have both seen a c channel frame absolutely bent skyward by doing exactly what you deem to be appropriate. Yikes!
    Snow likes this.
  10. bobinfleet
    bobinfleet Active Member
    446
    185
    Sep 2, 2011
    Hampshire UK
    I have no idea what a WDH is, but last year the A frame ( C channel ) of my 1994 viking broke in two. After I got it all welded up I looked into why it had snapped and found the tongue weight was 30 kilos over the permitted load stated in the owners manual. I presume it was over weight due to the change in hitch and jockey wheel and the addition of welded plates for them the importer had done. I had allways been careful not to exceed the tongue weight on my car but never thought about the pup frame.
  11. Snow
    10,183
    1,089
    WDH = Weight Distribution Hitch..
  12. BillyMc
    BillyMc Well-Known Member
    1,217
    574
    Mar 25, 2018
    The 97 Starcraft manual says not to use a WDH.
  13. GreyFox
    1,484
    715
    Oct 10, 2018
    S Ontario
    So too would I suspect the OP's Kia Sportage owner's manual also warn against using WD on any unibody vehicle. I've owned / used several WD systems and would only ever use one with a BOF (body on frame) vehicle such as a 1/2 ton truck.
  14. BillyMc
    1,217
    574
    Mar 25, 2018
    Another thing to consider is a larger TV. A Starcraft 2107 is pretty heavy for a Sportage.
  15. WrkrBee
    WrkrBee Well-Known Member
    2,587
    992
  16. bheff
    bheff Well-Known Member
    954
    464
    Feb 24, 2011
    NW Arkansas
    If you just have excessive sag in the rear (tow vehicle....body parts are a different topic) then maybe consider airbags. This is assuming that your weights are all within limits and you dont have any problem steering.
  17. durhamcamper
    743
    198
    Apr 21, 2010
    Pickering, Ontario
    Also, hoping he has working electric brakes on the trailer otherwise definitely overweight
