TSQ
Was under the trailer the other week giving everything a spring check and decided to overhaul the suspension prior to our long trip this summer.
Ordered up a Dexter K71-358-00 HD Suspension Kit which includes wet bolts, shackle links, and bronze spring bushings. This should fit most single axle trailers with 1-3/4" wide double eye springs (9/16 diameter bolts).
Fairly straightforward intall, as long as you have the tools and don't mind crawling around under your trailer. The included instruction cover it pretty well but I figured I'd do a little write up as well.
In part #2 I am also going to modify my rear hangers since they are the open type. Alternatively I could have bought a set of Dexter 030-020-00 rear hangers, but I think it'll be easier to just weld a bit of pipe inside my existing ones.
Tools I used:
- Jack
- Jack stand
- Grease
- Hammer/mallet
- Punch (not really required)
- Box wrenches (11/16 & 13/16)
- Torque wrench (good for 50 ft.lbs, w/ 11/16 socket)
1) Jack up the trailer and support the trailer frame with a jack stand.
2) Remove the wheel.
3) Take the weight off the spring using the jack under the axle.
4) Remove the three bolts - the are likely knurled under the cap so you may have to hammer them out.
5) Lower the jack/axle so you have room to work on the spring bushings
(note the old plastic bushing - I left my upper shackle link bolts in for now because I'm going to modify the hanger)
6) Slide one of the new bronze bushings over one of bolts your removed - if there is a knurled portion that the new bushing catches on file/grind it off first. Insert the end of the bolt into one of the old bushings.
7) Grease it all up
8) Hammer the new bushing in, which will push the old one out - make sure it goes in straight. If the old one won't come out cut it lengthwise from the inside using a hacksaw blade first.
(note the worn hole on the shackle link)
9) Install the new wet bolts and shackle links (except if, like me, you are going to modify the rear hangers) - you may need to hammer the knurled part of the wet bolt into the front bracket using a nut or socket or similar on the head of the bolt (to protect the grease zerk). I ended up tightening the nut a turn, giving it a few whacks, tightening a turn, etc until it was fully seated. Note that the instructions say to have the grease hole in the bolt at the side, not the top or bottom.
10) Torque them to 50 ft.lbs.
(I did install my front wet bolts)
11) Pump some grease into the wet bolts until it comes out the ends.
Don't forget to torque your wheel nuts when you put them back on.
I'll try and get around to modifying the rear hangers this week and post part #2.
Tools I used:
- Jack
- Jack stand
- Grease
- Hammer/mallet
7) Grease it all up
