Infinity Rod Creations
I like camping, it permits me to fish!
- Jul 17, 2008
- 61
Just installed the all new 12 volt system in a 88 coleman columbia and I'm working on the photo tutorial which should be up any day....
I do have a couple questions and I can't seem to find it in the owner's manual or written anywhere.
My new 8725 converter (starting from the bottom and working my way up the DC side of the fused output section) has a reverse polarity 30 AMP fuse (preinstalled at the factory) a red wire (which has a line of print that says positive feed from battery) and then three wires (blue, orange and yellow, I believe). When I first connected everything up, I couldn't figure out why a branch circuit wasn't working...then I read the face of the area where it said "Red wire is positive feed from battery" and figured out with a multi-meter that the red wire needed a fuse in it to feed the 3 circuits above it. I put in a 20 AMP fuse on this ciruit and the unit's fan fired up for a split second and the branch ciruit (an overhead light in the camper) works great. My question is this...what size fuse should I install into the red wire's feed (positive from battery terminal)? Right now it is a 20 AMP-er.
Also, I noted some things that I had to do differently. Since I only have a need for one branch ciruit for AC and it feeds an outlet only, I installed a 15amp circuit breaker and have the pig tail feeding this ciruit. I'm assuming that the other side of the this "pigtail" wire (the side that enters the converter on the inside of the panel) is a line used to feed the converter AC so that it can change it to DC in the charging of the battery?
My shore line power cord is only rated at 15 amp (it says it on the cord itself) so I thought it prudent to have only one breaker and a breaker that is rated at 15amps. I plan on getting a 30 AMP power cord soon, but for now...I don't see the point, unles...
Another question, the owners manual says to have the converter connected to 30 amp service and test to see if the converter is charging the battery. You would do this with a multi-meter and at the battery connection lines. If all is well, it should read 13.6volts output. Will it not charge if connected to 15 amp 110volt AC outlet? I haven't connected the Shore Power yet, just in case it would mess something up.
Thanks ahead of time!
Dj
Dj
