What and how are these used?
Discussion in 'Mystery Parts' started by Artist60164, Aug 16, 2019.
  1. Artist60164
    Artist60164 Active Member
    153
    39
    Aug 9, 2019
    The Windy City
    I have 4 and they seem to be folded around 2/3's of the vinyl.
  2. Shaman1
    Shaman1 Well-Known Member
    2,237
    508
    May 13, 2011
    Oklahoma City, Oklahoma
    That looks like a bag to hold some of your poles. What kind of camper do you have? Alternately, they might cover the lift arms on a pop up.
  3. RockyRoo
    6,538
    151
    Jun 8, 2012
    Not a great picture. How long and wide are they? Is there any velcro on it?
  4. Artist60164
    153
    39
    Aug 9, 2019
    The Windy City
    They are about 4 ft long and 5" wide some Velcro.
  5. Artist60164
    153
    39
    Aug 9, 2019
    The Windy City
    1983 Jayco JayCardinal
  6. bheff
    bheff Well-Known Member
    969
    471
    Feb 24, 2011
    NW Arkansas
    Could be lift arm covers
    kcsa75 likes this.
  7. Artist60164
    153
    39
    Aug 9, 2019
    The Windy City
    I think they are. I will have to see how they fit. Thank you.
  8. Artist60164
    153
    39
    Aug 9, 2019
    The Windy City
  9. bheff
    969
    471
    Feb 24, 2011
    NW Arkansas
    Looks like you arent perfectly level.
  10. Artist60164
    153
    39
    Aug 9, 2019
    The Windy City
    Omg could it be that simple? Only the one side of the leveler feet are down. I don't know how to get the other side down. 1983 Jayco JayCardinal.
  11. ezakoske
    ezakoske Active Member
    525
    75
    Nov 30, 2014
    Escondido, CA
    They are stabilizers, not levelers....You need to level the trailer side to side and front to back, before putting down the stabilizers to reduce movement.
    If you are using them to level the trailer, you are likely warping the frame which may be why the door isn't lining up.
  12. Sneezer
    1,547
    543
    Those are your roof lift arm post covers. There should be a screw up top where the lift arm is connected to your roof. Once the roof is up you just wrap them around the pole and secure with the Velcro. My 99 Jayco has them. They should not be loose - mine are attached by a screw at the top, and you just lay them out with the rest of the canvas when dropping the roof.
    generok and ezakoske like this.
  13. Artist60164
    153
    39
    Aug 9, 2019
    The Windy City
    Haaaaaaaaaaaaaa you are right. The fit perfectly around. I don't see a screw at the top, But I will look. So they stay in place when closing the pup? Awesome one less thing to find.
  14. myride
    myride Well-Known Member
    871
    393
    May 14, 2015
    Edmonton, AB
    No, you slip them OFF the lift arms prior to lowering and stow them. If left on posts you will not (and probably bugger up system) be able to lower roof.
  15. Artist60164
    153
    39
    Aug 9, 2019
    The Windy City
    That is why they were off folded and put in the compartment on the side of the camper THANK YOU SOOOO MUCH
