What could constantly be draining my new battery?
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by grsparty, Apr 17, 2019.
  1. Anthony Hitchings
    840
    373
    Mar 2, 2019
    80 milli-amps non stop
  2. Anthony Hitchings
    840
    373
    Mar 2, 2019
    Totally True - I got a free maintenance free battery of that voltage - it never came back to life
  3. MNTCamper
    MNTCamper Well-Known Member
    1,027
    285
    Jun 14, 2014
    MN
    I highly recommend installing a battery disconnect switch near your battery so that you can simply disconnect it when not camping. There are many to choose from and (ebay, amazon...) and they work great. It keeps you from manually having to disconnect all the time and as noted, the gas detector will drain the battery.
  4. joet
    4,965
    1,057
    And when you get another battery,,,,don't depend on a trickle charger to maintain it. A trickle charger will boil a battery. You want a maintainer, like a Battery Tender.
  5. grsparty
    grsparty New Member
    Mar 5, 2019
    I wondered about this when I first checked it. Yes, I am sure I checked it correctly with my multimeter. Now, I’ll have to do some research on what to buy. Group 24, 27, 31 versus 6v in a series, or AGM blah, blah, blah.
    I feel like I’m going to get overwhelmed quickly....
  6. grsparty
    grsparty New Member
    Mar 5, 2019
    Yes, battery tender is what I have.
  7. tenttrailer
    3,348
    415
    Jul 18, 2013
    Thornville, OH
    +2, The specs on most of these trickle chargers there is a low voltage limit. If the battery is at or below a certain voltage the charger will not even try to charge.
    Propane detector. On many campers it's on all the time. I had a popup I would remove the fuse that the detector was on when storing the camper. Most detectors will chirp a few times when the voltage is removed. Try removing all the wires on either the negative or negative terminal and see what it does.
  8. GreyFox
    GreyFox Well-Known Member
    2,026
    1,011
    Oct 10, 2018
    S Ontario
    Although I suppose there may be an exception out there somewhere it would be more accurate to say of any trailer manufactured in at least the last 25 yrs that the propane detector (more commonly these days a combo CO/LP detector) would be hard wired into the trailer's 12 vdc system and would be on all the time. If one doesn't plug the trailer into shore power while it's being stored so the converter can maintain the battery charge or doesn't disconnect the battery when no shore power is available, either physically or with a disconnect switch, then the detector alone can over the course of a couple of weeks absolutely draw that battery down to the point where it's been destroyed.
  9. MNTCamper
    1,027
    285
    Jun 14, 2014
    MN
    On the battery side, I can recommend a good group 31 deep cycle. I got mine at Sam's club, Duracell (which is East Penn). $80 on sale. I can go 10 days with no hookups.
  10. Brett1962
    Brett1962 New Member
    Feb 20, 2019
    N.E. Arkansas
    CO/LP detector and Radio is always drawing off mine unless I remove the in-line fuses.
    **Go for the maintainer for the battery!!
  11. grsparty
    grsparty New Member
    Mar 5, 2019
    I think a group 31 is a tad big for my needs. Majority of my camping, I’ll be hooked up. I’ll probably go for a 27 with a small Zamp solar panel.
    I have a battery tender. Good to go now that I know I need to disconnect.
  12. GreyFox
    2,026
    1,011
    Oct 10, 2018
    S Ontario
    Did your dealer not go over this when you got your orientation for your new camper? Should have - now you know why. ;)
  13. Snow
    10,573
    1,340
    Two trailers and no mention from either dealer about it.. I found out by asking others..
  14. GreyFox
    2,026
    1,011
    Oct 10, 2018
    S Ontario
    Same answer - should have, now you know why. ;)
  15. rabird
    6,929
    401
    N. TX
    disconnect the neg side first the the pos. reconnect the pos side first then the neg.
    grsparty likes this.
  16. WingmanHG
    WingmanHG Member
    84
    75
    Mar 15, 2019
    Maricopa AZ
    A lead acid battery will self discharge ~5% per month just sitting on a shelf. I’d charge it up and do a test run see if it’ll run your lights and fans long enough for you. (Btw switch everything to LEDs it’s a cheeep solution to extend battery life) or after your tender says it’s charged and good to go take it to any auto parts store and they’ll test it for you. It’s probably damaged but may still be serviceable for a camping season or 2. But definitely put on a master shut off switch so u only loose that ~5% a month. I out mine right at the battery in the top of the battery box
  17. grsparty
    grsparty New Member
    Mar 5, 2019
    They did not, probably to get me back in to buy a freaking new battery. [:(!]
  18. WrkrBee
    WrkrBee Well-Known Member
    3,196
    1,332
    I still think that people "designing" campers do not camp in them. If so, they would all have a battery disconnect switch. They also, do not read reviews on their products.
    brwarrior, arge and WingmanHG like this.
  19. eoleson1
    eoleson1 Well-Known Member
    2,452
    839
    Jul 5, 2011
    Macomb County Michigan
    Is that battery box something you bought, or something you created?
  20. WingmanHG
    WingmanHG Member
    84
    75
    Mar 15, 2019
    Maricopa AZ
    https://smile.amazon.com/gp/aw/d/B004GH11MO?psc=1&ref=ppx_pop_mob_b_asin_title
    This is the battery box i used. I put a kill switch between the + terminal on the battery and the + post on the box.
    https://smile.amazon.com/gp/aw/d/B07413JWLD?psc=1&ref=ppx_pop_mob_b_asin_title
    I put a simple on off 2 position switch between the + side of my battery tender and the battery
    https://smile.amazon.com/gp/aw/d/B07894CFCR?psc=1&ref=ppx_pop_mob_b_asin_title
    https://smile.amazon.com/gp/aw/d/B07D28XPKV?psc=1&ref=ppx_pop_mob_b_asin_title
    eoleson1 likes this.
