What do I use to clean windows.
Discussion in 'Miscellaneous Repairs & Maintenance' started by pisces32, Sep 18, 2019.
  1. pisces32
    pisces32 New Member
    Sep 18, 2019
    Hello,
    I recently purchased a 94 starcraft popup and the back of the curtains (which is I think plastic.) melted to the windows. I have tried many different cleaning products and found nothing that will remove it.
    Any suggestions??
  2. bheff
    bheff Well-Known Member
    1,468
    862
    Feb 24, 2011
    NW Arkansas
    I'm affraid you are stuck with how it is.
  3. Sjm9911
    5,951
    3,408
    Try pleage , may or may not work, but will help from becoming more damaged.
  4. Econ
    Econ Well-Known Member
    665
    317
    Aug 18, 2019
    Deep South
    <<<melted to the windows.>>>>>]
    Are the windows glass? If so try this in a small area first. Get a brand new single edge razor blade. They can still be found in hardware and construction goods. Mark one side as up and always keep it up. The blade can get micro burs and scratch if up goes down. Scrape the plastic off. A great way to remove bumper stickers, etc from glass. Also if glass, you can apply heat to soften it up. Remember, test first before going crazy.
  5. bheff
    1,468
    862
    Feb 24, 2011
    NW Arkansas
    She posted a picture. I have never heard of a glass window in a soft sided camper.
  6. Econ
    665
    317
    Aug 18, 2019
    Deep South
    Sorry, that time of morning is before the second pot.<GG>
  7. McFlyfi
    McFlyfi Active Member
    488
    220
    Aug 1, 2014
    Thousand Oaks CA
    I've used Plexus with good results. I didn't have anything as severe as you, but it might be worth a try.
  8. jeeper88
    jeeper88 Let's go Camping and Jeepin
    883
    63
    Apr 24, 2011
    Ocala,FL
    If you check on ebay you will find some pup windows and parts.. I found one for my westlake used but in better shape than the one I had.
  9. David Branley
    David Branley Member
    34
    Jul 31, 2018
    I recently used protect all on my windows which were yellow and covered in black marks. They came up like new!
